Old 01-30-2006, 05:23 PM   #1 (permalink)
Default 1989 Range Rover stalls when cold
I have a 1989 Range Rove that stalls out when the motor is cold. and then it is hard to restart this only happens in the first five miles of driving if I let it warm up for Five minutes or so it runs fine.
Thomaswa is offline   Reply With Quote
Old 01-30-2006, 06:19 PM   #2 (permalink)
RageRover's Avatar
Spark plugs might be starting to foul out...a dirty fuel filter or a restriction in the fuel system...a dirty throttle body and plate...a sensor is not reading right for idle. All these are possibilities, plus I haven't gotten know my motor like an expert yet. A simple tune-up might be in order. If that helps.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 01-31-2006, 05:34 AM   #3 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
I would suspect something in the fuel system dealing with the cold startup as you state. Like the air temp sensor, air flow meter, cold start injector or something. Do you have a LR shop manual? There is a pretty good writeup on the fuel injection system and how to test the different systems in it.
Old 02-04-2006, 03:39 PM   #4 (permalink)
Default all fixed
I cleaned the throttle body with WD-40 and then carb cleaner and all is good.
