Old 01-24-2005, 02:38 PM   #1 (permalink)
Default 1992 RRC Stalling
My 1992 Classic is stalling occasionally. This seems to only happen while or after driving at high speed on an interstate. I put the truck in neutral and in three tries it restarts and I don't have the problem again for a while.
I'm thinking air filter or catalytic converter? Thoughts?
dbrisotti is offline   Reply With Quote
Old 01-24-2005, 05:15 PM   #2 (permalink)
How long has it been since you have done a tune up? Plugs, wires, cap and rotor.
lonestarrover is offline   Reply With Quote
Old 01-24-2005, 10:41 PM   #3 (permalink)
Landy-Andy's Avatar
Default Stalling Range Rover.....
Hi Dbrisotti,
Here is some helpfull info from the RRRemedies web site;
Its pretty detailed, but makes interesting reading,
Good Luck,
Andy
Stalling
A common problem on Range Rover Classics is an annoying tendency to stall when you come to a stop after a long run. Kevan Wiser repports his procedure for fixing this periodically recurring problem.
1) Be certain the flame trap isn't blocked--remove it and check the "mesh wad" It just unscrews from the top-front of the PS valve cover.
2) Check the T-piece that connects the vacuum hoses going to the plenum--it's the obvious one central-front behind the distributor.
3) Clean the stepper-motor plunger and seat. this is easy to do is usually what corrects the problem for Kevan. He uses "brake cleaner" and a toothbrush to clean the plunger assembly making sure to clean the head that has to mate w/ the seat. Then, he uses a rag dipped in brake cleaner to clean the seat itself. He has read that others have used a bit of white grease to lube the plunger, but he always just gives it a shot of what ever WD40 - like substance is handy. For more on the care and feeding of this pesky and temperamental component, see the section on the idle air bypass valve/stepper motor above.
Joel Mahoney experienced similar symptoms on his LWB. It would stall out at stop signs and red lights and also to bog down (and register horrible gas mileage!) when driving on the highway. Both of these occurences were fairly intermitant, which made it difficult to diagnose. After replacing many other components he noticed that the problem seemed to worsen over bumpy roads, indicating some kind of wiring issue. He went into the engine and started pulling on various wires, and found the lead from the harness to the ignition module pulled right out! After re-wiring the connection with new butt-connectors, and tightening them down properly, the vehicle has run without a stutter ever since!
Greg Olma reports that cold stalls may be your coolant sensor or the wiring for it. He states "My 89 would stall and be hard to start all the time before complete warm up. The sensor is telling the ecu to lean the mix out too soon. When warm it was fine. I took to two foot driving to keep up the the idle speed when stopped at lights, etc. I noticed that Saab 900 and VW Golfs from the late '80s had an identicle looking sensor and plug. My plug was cracked, so I pulled a Saab and a VW set up and Voila! it worked perfectly, No stalling and tough starting when cold again".
Larry Michelon reports that a dirty Mass Air Flow (MAF) sensor has caused stalling upon startup, refusal to idle when hot and excessive fuel consumption on both his RR Classic and his 97 Discovery. He first discovered it on his Disco when it generated an OBD-II fault code indicating "exceeding max air percentage". Cleaning the sensor solved the problem. On his Classic, he zeroed in on the MAF sensor incorrect air mixture message after his attempts to fix the stalling problem by changing idle air control valve did not work. During his investigations he accidentally disconnected the MAF sensor, and found that it made little difference -- leading him to suspect it might be inoperative. After removing the snap ring and screen, he gave its insides a good lean by injecting the following into the sensor hole: WD-40, diluted simple green, water, and low pressure air (the latter two to flush out any residual lubricant). If he was doing it again he would use tuner cleaner (the TV stuff available at Radio Shack), but would still recommend flushing out the lubricant/cleaner.
Hot Stalling while running on the highway has been reported by a couple of owners to be due to a bad coil. Howard Lefkowitz had such a problem on his 92 model several years ago. After plugs, points, distributor cap, plug wires etc. he noticed a white substance coming out of the coil. "New coil and problem fixed." It is interesting to compare this experience with that of Walter Gates on his 4.0 which had stuff exuding from the coil (see 4.0/4.6 coil page).
James Howard reported another source of stalling problems that turned up on his father's 93 model -- while driving, the engine would occasionally "load up", then quit running. Most of the time you could turn the switch off and then restart it while rolling along at 40+ mph, after which the engine ran perfectly. The problem was often associated with a code 69 "Gear selector switch or circuit" on the underseat diagnostic code readout box. After replacing the switch to no avail, he took it to the dealer. Their tech knew exactly what it was, because he had seen it before. There is some wiring for the gearbox circuit up in the fender that can get damaged. When that happens, an incorrect signal is given to the computer, which confuses it, and causes the running problems and stalling.
Landy-Andy is offline   Reply With Quote
Old 01-25-2005, 07:10 AM   #4 (permalink)
Great info... I will read all of it before bed tonight.
As for the tune up... it just had one along with having all the high pressure hoses replaced in the engine. This has to do with high speed, long term driving and it always restarts. It just takes a few tries (always three actually... weird). I normally shift into neutral and haven't even stopped before it restarts.
I'll let you know. Thanks.
Old 01-26-2005, 07:13 AM   #5 (permalink)
OkieRover's Avatar
Gallery: 2
What is the URL for that RR Remedies site?
I punch my clown daily.
Old 01-26-2005, 08:54 AM   #6 (permalink)
Default URLs
http://rangerovers.net/rremedies.htm
Kevin
88 RRC "Audrey"
Old 01-27-2005, 12:24 PM   #7 (permalink)
OkieRover's Avatar
Gallery: 2
danke
Old 01-27-2005, 01:49 PM   #8 (permalink)
DrewInSD's Avatar
Default idle adjustment
I had a similar problem with my 87 RRC a while back. It would stall at stop lights, after getting off the freeway, and always when I pulled into garage.
My mechanic simply adjusted the idle up just a bit and it hasn't stalled since.
Hopefully your fix will be that simple!
Drew
DrewInSD is offline   Reply With Quote
Old 01-31-2005, 07:51 AM   #9 (permalink)
Exclamation More interesting now
While it continues to restart, it has begun to lose power at times. I can have the accelerator to the floor and not get over 40 miles per hour. White smoke occasionally comes from the tailpipe and the airflow is hindered considersbly as well.
I'm thinking CATALYTIC CONVERTER... anyone disagree? The only thing that might make me think it's a gas mixture issue is that if I put high grade gasoline in it it runs better with less stalls and more power. Hmmm...
Old 01-31-2005, 09:30 AM   #10 (permalink)
Underwater hockey is no dumber than any other sport
Roverdude's Avatar
Could also be the ignition amplifier module, little box located on the side of the distributor. It overheats under the hood, engine stalls out. Cools doen a little later, engine runs, then stalls again. Not too difficult to replace, but a little pricey (at least $100).
Roverdude is offline   Reply With Quote
Old 01-31-2005, 09:32 AM   #11 (permalink)
OkieRover's Avatar
Gallery: 2
You loosing any antifreeze?
I wonder if you lost a head gasket.
Old 01-31-2005, 12:31 PM   #12 (permalink)
Landy-Andy's Avatar
Default White smoke....
Is it possible that the white smoke could be steam??
Then as Okie say's it could be a head gasket gone that is letting coolant steam through the exhaust system?
If your not losing coolant the white smoke normally points to a weak fuel mixture, some kind of restriction in the fuel supply line? Have you checked your fuel tank breather tube? If air cant get into the tank to replace the fuel your taking out then a vacuum is created causing stalling, rough running & white smoke? Worth a look. Also check your fuel filter if you haven't changed it lately.
I don't see it being a cat. convertor, but I've been wrong before!!
good luck,
Andy
Old 01-31-2005, 03:38 PM   #13 (permalink)
I am going out of town for the week... but the fuel filter sounds right. I have the new one and haven't put it in yet. I'm not loosing coolant. I'll let you know.
Thanks!
