Old 06-04-2008, 01:17 PM   #1 (permalink)
Default 1994 Classic strange shifting trans
the other day my 1994 Range Rover Classic LWB started doing something new. when i got in to go to work it seem to stay in 1st gear until high rpm then shifted on through the gears as normal. it drove fine after that. shifted maybe around 4000 rpm. next day same thing happen again. seems to only happen after car has sat for many hours (overnight). if anyone has any ideas on this i would appreciate greatly.
hawaiirover is offline   Reply With Quote
Old 06-04-2008, 04:03 PM   #2 (permalink)
Eric D's Avatar
Have you checked your ATF level?
Do so on level ground.
Also check for ATF leaks at the trans pan and body, cooler hoses and radiator.
Eric D is offline   Reply With Quote
1994 Classic ABS brake bleeding procedure hawaiirover Range Rover Classic 2 06-04-2008 01:12 PM
Strange overheating problem for my 88 Classic. dfarnham Range Rover Classic 7 06-14-2007 08:29 PM
1994 RR Classic 4.2 No power to coil PARIDAH Range Rover Classic 9 03-10-2007 05:12 PM
Automatic Trans Cooling Lines Irvin Range Rover Classic 0 01-18-2005 08:24 PM
1994 Range Rover Classic 4000 obo staples13 Land Rover Vehicles 1 08-26-2004 12:45 PM
