Old 02-11-2007, 04:49 PM   #1 (permalink)
Question 1994 RR Classic 4.2 No power to coil
I purchased a 1994 RR Classic. I was recieving intermittent spark. The truck will not start. After checking and running 12v directly to the coil . I now do not have power to the coil either. Please help where should I begain to look . I have also purchased a Mallory Dizzy Unilite, coil, and ballast.
PARIDAH is offline   Reply With Quote
Old 02-12-2007, 03:42 AM   #2 (permalink)
Super Moderator
Disco's Avatar
My long range diagnostics of your coil is that you have a problem on the ignition side of the coil. Check for loose wires or a poor earth, hence the intermittant spark.
Old 02-12-2007, 06:33 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
And fuses.
I punch my clown daily.
Old 02-12-2007, 02:53 PM   #4 (permalink)
Originally Posted by OkieRover
And fuses.
Exactly what fuse should I check and where is it located?
Old 02-13-2007, 07:18 AM   #5 (permalink)
OkieRover's Avatar
Gallery: 2
Inside the cab. On the fuse block there is a coil fuse. It's labeled with a lightning bolt over an engine I believe.
Old 02-28-2007, 05:02 PM   #6 (permalink)
Sorry it took soo long for an update. I replaced the 10amp fuse in the fuse block. Now I have power to the coil. I replaced the original coil with a Mallory coil and ballast. I still have no spark from the coil to the dizzy. I removed the HD lead held it close to ground, and no spark. Does anyone have the correct wiring configuration i.e. white black and white connection in relation to the + and - leads on the coil? Thanks
Old 03-01-2007, 06:52 AM   #7 (permalink)
OkieRover's Avatar
Gallery: 2
That truck is at home.
I'll take a pic when I get there for you. I'm not sure if our color wires are the same but I'll look at it and send ya pic tonight.
Old 03-10-2007, 11:19 AM   #8 (permalink)
Default Install complete
Today we had some nice weather. I got Mallory Dizzy&Coil installed. New Battery. I installed the Mallory leads as follows G/BW/BW to neg. post on coil and 1 lead from neg. to ground on fenderwell, w to ballast resistor in/ w to pos. lead on coil red to pos. lead on coil. I have no power to coil when I turn the engin over. Once the key is released I see a quick flash on the test light. I have run a lead directly to the positive side of the coil and still have no spark. what is going on. Bad ing switch? I am lost.
Old 03-10-2007, 01:24 PM   #9 (permalink)
Default I now have power to coil
Following recommendations from board members via tele phone. I removed the cowl from the steering colum secured the back of the ignition harness, and now have power to the positive side of the coil. I still have no spark, the coil got hot cranking it over for a while. Any idea why I still dont have a spark, and the heat issuer with this mallory electronic coil?
Thank Paridah
Old 03-10-2007, 04:12 PM   #10 (permalink)
I had the same problems, and after exhausting all ignition system avenues... I replaced the alternator and she fired up perfect
tlry00 is offline   Reply With Quote
