Old 11-24-2007, 08:41 PM   #1 (permalink)
Default 1995 LWB Transmission shifting problem
I just got my 95 RRC LWB yesterday. It had a rebuilt transmission installed 2 months ago by a LR specialty shop.
Today, the transmission started acting up and it wont shift out of 1st gear. Itll go to about 3500 rpm in 1st gear and then starts slipping.
I read that this problem is usually associated with the governor sticking due to old transmission fluid/filter - but what would cause a freshly rebuilt tranny to do this?
Is there a break in period after which the fluid needs to be changed again?
I haven't contacted the shop but should it be expected that the tranny is covered by some kind of warranty?
Thanks for the replies!
serge9444 is offline   Reply With Quote
Old 11-25-2007, 02:28 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
Most reputable shops will have at least a 12k/12 month warranty on a rebuilt. Many have a much longer warranty period
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 11-25-2007, 07:19 PM   #3 (permalink)
hell I did my own overhaul on my 87 about 4 years ago when I burnt it at MAR, so far 4 years almost 50.000 miles pulling a trailer with up to 8,000 lbs total load for some 12,000 miles of those 50 and not a single slip,(knok on wood) I have used sinthetyc ATF since the overhaul, probably 1,500 of those are off road miles, filter and oil changes every 12k or once a year which ever occurs first.
carlosz is offline   Reply With Quote
Old 11-26-2007, 12:26 AM   #4 (permalink)
Well, seems like I fixed the problem - I floored the accelerator and once the tach hit almost 6k the transmission finally shifted. Been working normally since... Hopefully this wont turn into a reoccurring problem.
transmission problem duckslayer Range Rover Classic 7 10-31-2008 09:27 AM
transmission problem? rhc Discovery Series II 1 07-30-2006 02:21 PM
Transmission Problem in a DII cbriggs3 Discovery Series II 10 12-17-2005 11:05 AM
Transmission Problem - Any Ideas ???? Rascal1003 Freelander / LR2 6 12-08-2005 12:16 PM
Intermittent Driveline Vibration at 60MPH AdrianL Range Rover Classic 10 06-24-2005 08:52 AM
