I am also getting a violent shake when i push on the accelerator while driving come to find out it was the universal joint going bad. Damn, while driving i heard a loud bamm. roto flex broken and hit my transmission box and transmission fluid all leak out. can someone tell me what the worst can happen to the transmission?
Otherwise known as STEVE
How did a rotoflex cause a driveshaft to hit the transmission? The rear driveshaft is BEHIND the transmission. Are you sure you didn't just break a regular ujoint on the front shaft or something?
If it's leaking fluid etc, you probably broke the housing and need to replace the transmission. Common when a front shaft breaks a u-joint, but not as common when a rear shaft goes.
i am sorry but it was the front shaft that broke lose from the u-joint. it broke and the transmission fluid leak out. I mean all of it. but how can i tell if i have damaged the trans. I was able to pull of the road immediately and get a tow truck to take my truck home. if it is damaged please let me know if a new trans or a used one is better.
A new transmission will cost you more than the truck is worth. Get a good used one for $300 or so. You really need to find where the leak is coming from, but it's not unheard of for a front shaft to whack the housing and break it.
what i really mean is that the drive shaft broke of its attachment and hit the bottom of the transmission pan broken the broken a piece of the bottom that attaches between the gasket and the transmission pan. how do i get something welded to keep the transmission fluid from leaking out of the transmission. what i mean is that the bottom that attaches to the transmission pan has a broken piece out of it. so i need something to gave me a flat service to be able to replace the pan or i will not be able to put in transmission fluid.
