Old 02-06-2007, 08:42 PM   #1 (permalink)
Default 1995 Range Rover Classic Broken Roto Flex
I am also getting a violent shake when i push on the accelerator while driving come to find out it was the universal joint going bad. Damn, while driving i heard a loud bamm. roto flex broken and hit my transmission box and transmission fluid all leak out. can someone tell me what the worst can happen to the transmission?
tebelleh is offline   Reply With Quote
Old 02-06-2007, 10:35 PM   #2 (permalink)
Otherwise known as STEVE
How did a rotoflex cause a driveshaft to hit the transmission? The rear driveshaft is BEHIND the transmission. Are you sure you didn't just break a regular ujoint on the front shaft or something?
If it's leaking fluid etc, you probably broke the housing and need to replace the transmission. Common when a front shaft breaks a u-joint, but not as common when a rear shaft goes.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 02-07-2007, 05:57 AM   #3 (permalink)
i am sorry but it was the front shaft that broke lose from the u-joint. it broke and the transmission fluid leak out. I mean all of it. but how can i tell if i have damaged the trans. I was able to pull of the road immediately and get a tow truck to take my truck home. if it is damaged please let me know if a new trans or a used one is better.
Old 02-07-2007, 07:43 AM   #4 (permalink)
A new transmission will cost you more than the truck is worth. Get a good used one for $300 or so. You really need to find where the leak is coming from, but it's not unheard of for a front shaft to whack the housing and break it.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 02-07-2007, 01:05 PM   #5 (permalink)
Default broken dirve shaft
what i really mean is that the drive shaft broke of its attachment and hit the bottom of the transmission pan broken the broken a piece of the bottom that attaches between the gasket and the transmission pan. how do i get something welded to keep the transmission fluid from leaking out of the transmission. what i mean is that the bottom that attaches to the transmission pan has a broken piece out of it. so i need something to gave me a flat service to be able to replace the pan or i will not be able to put in transmission fluid.
