Old 02-04-2007, 07:10 PM   #1 (permalink)
Default 1995 Range Rover Classic ECU
where is the ECU and what does it look like and how can I read the code of it. Is it just being display with the code numbers on it or not.
tebelleh is offline   Reply With Quote
Old 02-05-2007, 12:13 AM   #2 (permalink)
The ECU is on the outside wall of the passenger footwell. The OBDI code reader is under the passenger seat. If you remove the plastic seat frame cover facing the passenger door you will see the display. It is a small palstic box about 3"x2" in size.
Old 02-05-2007, 03:48 AM   #3 (permalink)
will that be the little brown box? if that is it where is the code supposed to be?
Old 02-05-2007, 06:48 AM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
Are you looking for the display for the OBD2 error?
ECU encompasses so many things. There is a window ECU, etc...
I punch my clown daily.
Old 02-05-2007, 12:15 PM   #5 (permalink)
thanks very and I found it. i am receiving code 02 which is states that
This code means power to the ECU has been disconnected and the truck has not yet been started. This code should go away as soon as the vehicle is started for the first time. Appearance of this code while driving may signal a problem within the ECU.
how do I fix this problem? or how do verify that the connection to the ECU is working?
Old 02-05-2007, 01:13 PM   #6 (permalink)
OkieRover's Avatar
Gallery: 2
02 for me is an ignore message.
It should go away.
If you have another number then there is a problem.
Old 02-05-2007, 05:46 PM   #7 (permalink)
WWTSD? (what would Tony Soprano do?)
stevo-II's Avatar
Maybe you've got a problem with the constant 12V wiring to the ecu - i.e. everytime you turn off the key it thinks power has been disconnected.
2001 D2 -The Stevo-II
1992 RRC-The Stevo-I
stevo-II is offline   Reply With Quote
