Old 06-19-2006, 03:38 PM   #16 (permalink)
RageRover's Avatar
Ok, now it is time for me to start acting on getting the shifter to start working again, and it is a pain in the ass to do!!!
This is what I have done so far:
Taken apart the whole damn center console...
Lubed the hell out of the linkage from the shifter to T-case...
Disconnected the wiring from the shifter (solenoid wires), which then breifly allowed me to shift into Neutral for a bit, I know this cause when I put it into Drive to test it, the truck did not go anywhere, now, after shifting back and fourth to H and N, she now still locks in H.
I reattached the wires to see if that solenoid would reset it self, but nothing.
Now I have a half torn apart interior and a range shifter that doesn' shift at all, what should I move onto next?!
This is quite challenging to get it working.
Also if I have to drill those rivets on the tunnel for the tranny that houses the shifter for the t-case, can I use something other than rivets to put her back in?
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 06-19-2006, 03:54 PM   #17 (permalink)
ryans ROVER
ryanc8514's Avatar
i am also workin on the same thing...i have my whole center console taken apart but i havent taken out the rivets yet...hopefully i wont have the problems you have...keep us updated if u figure out whats stopping it from shifting...could the gears be completely torn up?
ryan mura
1994 range rover county lwb
-BIG BLUE 3" coil spring suspension lift
-Procomp ES3000 shocks
-custom snorkel
-glasspack exhaust system
-285/75/R16 all terrain tires
-old school CB radio from the 80s-cobra
-speakers loud enough to set off car alarms
-LR3 side air vent
ryanc8514 is offline   Reply With Quote
Old 06-19-2006, 04:06 PM   #18 (permalink)
RageRover's Avatar
No, I don't think so, otherwise, the shifter would shift loosely, and nothing would be engaging when shifted.
Yeah I will try to keep updated on this, I might have to try removing that solenoid but from what I see, it is built in and no easy way of removing it.
1995 RRC LWB
Old 06-20-2006, 03:58 AM   #19 (permalink)
Magicly Delicious
Bene's Avatar
I drove around for about a month before I found out about that solenoid. just take it out, you wont regret it.
Kevin
1994 Discovery
Old 06-20-2006, 06:28 AM   #20 (permalink)
sven's Avatar
Pat, try this..
Disconnect the wires from the shifter, then try to goto "L" while slightly rolling the truck. See if that does it.
Old 06-20-2006, 11:38 AM   #21 (permalink)
RageRover's Avatar
Ok, I will give it a shot once again later today.
What would else be the problem if it doesn't shift into LO? Yesterday I managed to get it into Neutral, with the wires disconnected, but it took a good wiggle to to get the shifter to move. Also the linkage, I blasted with a shit load of WD-40, seemed to help, not really.
But yeah I will try again later today with a rolling start.
1995 RRC LWB
Old 06-20-2006, 05:56 PM   #22 (permalink)
RageRover's Avatar
Angry Frustrating!!!
Well, not surprisingly, after doing a very slow rolling start, the shifter, with no wires plugged into the shifter solenoid, didn't even shift into Neatral or LO.
I dunno what else to think, I might have to try drilling the rivets for the shifter on the tranny tunnel and get a good look.
1995 RRC LWB
Old 06-20-2006, 10:28 PM   #23 (permalink)
ryans ROVER
ryanc8514's Avatar
ok i figured it out!!
take out the center consol and everything covering the shifter, u have 2 drill out the revits..once you can see everything unplug the solenoid wire and loosen the allen wrench bolts, take off both bolts holding the solenoid to the shifter, pull the solenoid out and wahlah problem solved! let me kno if u have any problems
ryan mura
-custom snorkel
-LR3 side air vent
Old 06-20-2006, 10:35 PM   #24 (permalink)
RageRover's Avatar
Hey Ryan, your RRC LWB, does it have the Borg Warner T-case? I think it does, yeah it should, yours is too a 94' like mine. I will check into this!!! Thanks plenty!!!
1995 RRC LWB
Old 06-21-2006, 12:22 AM   #25 (permalink)
rovering??
1st rover's Avatar
its not as hard as it sounds its just a labor intensive process. tp put it back to geather you can use scrues also but i would say use rivits as they hold better and its fairly easy to put them in.
if u dont have a rivet gun get one from big lots for about 5 bucks and a big nox of rivets from any hardware store for about 5 bucks too.
-Nikunj
1993 Range Rover Classic LWB
1995 VW JETTA
1st rover is offline   Reply With Quote
Old 06-21-2006, 12:32 AM   #26 (permalink)
RageRover's Avatar
DAMN THAT IS CHEAP FOR A RIVET GUN!! I might just do that tomorrow then. I hope after this the shifter will then work.
1995 RRC LWB
Old 06-26-2006, 02:04 AM   #27 (permalink)
RageRover's Avatar
Almost forgot to say something: I got the lever to work, after a pain in the ass job of drilling the rivets from the cover and breaking two friggen' drill bits in the process. Turns out it was the solenoid, frozen in the locked position, and I could just barely move it with a screw driver to unlock, so I said screw it, and left it off. Now everything works. Yay, I got Lo Range now. LOL
1995 RRC LWB
