Old 08-03-2005, 11:22 AM   #1 (permalink)
Default 58-63 vibration update
First, went to dealer for check on vibration. Frist mistake. Dealer quoted $2100 for the complete front transfer case. Hell with it.
Went to my mechanic. I did not go to him because he was on vacation. Checked, drove around. He told me to be on saf side, suggested flush and refill the fluid. Changed fluid to synthetic. Test drove. No vibration, No noise. cost? $14.75.
He also fond three tie rod ends bad, and replaced it under warranty.
AdrianL is offline   Reply With Quote
Old 08-03-2005, 11:27 AM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
Front transfer case? Adrian, there is only one transfer case, are you talking about the front driveshaft?
How could changing the fluid in the transfer case get rid of a vibration? I think your problem was the tie rod ends and not the TC or driveline.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 08-03-2005, 12:09 PM   #3 (permalink)
Default Front Differential Not trasnfer case
Maybe. But we did the test drive afte the fluid was changed. No viration or noise. After that, my mechanic put the car on the lift to do the final inspection and found the tie rod end being bad. Don't ask me why the fluid would have fixed, but I am happy
