Old 02-13-2006, 07:38 PM   #1 (permalink)
who that is?™
Explorer4x4's Avatar
Default 88 RRC...no HVAC fan
Well, I went to turn the heat on today and the fan wouldn't come on. It was working about 2 weeks ago for sure...but the last few times I drove it I haven't tried to turn it on. Where should I start looking for the problem? THe fuse is not blown. I really hope the fan isn't bad.
1995 Disco on 33's
1988 Range Rover- trimmed fenders, big rack, HIDs,...
2000 Turbocharged Explorer 5.0 AWD....'tis fast
2005 Ford F150 4x4... company vehicle
Explorer4x4 is offline   Reply With Quote
Old 02-13-2006, 07:49 PM   #2 (permalink)
Dont know if this will help. Mine went out a while back too. It works only on high. Need to swap out the resistor that I haven't got around to do. Might want to check it.
Randy
90 RRC
225,000 mls
rover1 is offline   Reply With Quote
Old 02-13-2006, 07:54 PM   #3 (permalink)
who that is?™
where is it exactly?
1995 Disco on 33's
Old 02-13-2006, 08:00 PM   #4 (permalink)
here it is. I am not very fast at typing but I can cna copy and paste like crazy.
http://jpurnell.com/RR/repairs/heate...d_resistor.htm
I thought I had a photo.
Randy
90 RRC
225,000 mls
Old 02-14-2006, 12:20 PM   #5 (permalink)
The resistor in my 88 RRC is inside the heater unit itself- dismantling the dash is he "only" way I could get to mine- If it blows on hi, but not med and low- thats a clasic resistor problem- if it doesn't blow at all- thats something else-
Mine blew very porly- no airflow- but the motor ran low-med-high- changed blower motors- lots of air.
There is some talk about a blower motor relay you ight want to check- or the switch itself may be bad. Don't know where the relay is, but the switch can be pulled fairly easily.
Good luck.
Kleantouch is offline   Reply With Quote
Old 02-14-2006, 05:44 PM   #6 (permalink)
Otherwise known as STEVE
We sell a lot of replacement resistors... but if you're in there, which takes a long time, might as well do the motor too.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 09-28-2006, 02:41 PM   #7 (permalink)
who that is?™
I am bringing this post back from the dead because I am still having the problem.
More details....
The fan switch causes the radiator fans and the compressor to some on leading me to believe the switch is good. There is no fan on heat or AC. I read in another post that there is a fuse for the AC under the passenger seat, but I cant find any fuses under there.
How does the AC fan come loose so I can test for voltage?
1995 Disco on 33's
Old 09-29-2006, 07:44 PM   #8 (permalink)
1993 Range Rover County LWB
Does an '88 have separate blowers for heater and AC, or just a single blower?
- Ian
1993 Range Rover County LWB / 1996 Rover Mini SPi / 1965 MG 1100
heiff is offline   Reply With Quote
Old 09-30-2006, 05:17 PM   #9 (permalink)
WWTSD? (what would Tony Soprano do?)
stevo-II's Avatar
Separate, you should see the two a/c fans by looking up from the passenger side floorboard, the heater fan is buried in the dash.
Steve
2001 D2 -The Stevo-II
1992 RRC-The Stevo-I
stevo-II is offline   Reply With Quote
Old 10-01-2006, 11:31 AM   #10 (permalink)
who that is?™
Steve
I see AC blowers, and I can see the wires running to them, but I cant get to them for testing. Where do these wires originate?
1995 Disco on 33's
