Old 12-02-2007, 04:56 PM   #1 (permalink)
Default '90 LR Classic Electrical Mystery
Hello:
Got a couple of '90 LR Classics & both seem to have electrical problems after of course some "expert" installed Burglar alarms & upgrade radios.
The grey LR will start & run great then suddenly stop & not restart, then after sitting for awhile start up & run again then stop.
How can you check the ignition module attached to dist. when removed?
How can you check to see if relays work?
I've switched modules/dist/relays/Box under pass seat & still will not start.
HELP.
Kit
kauaikit is offline   Reply With Quote
Old 12-03-2007, 05:20 PM   #2 (permalink)
DevynsDad's Avatar
Check your coil, man. If it's getting to hot it'll stop working until it cools off, then start right back up again.
1990 Range Rover County
2002 Jaguar X-Type
DevynsDad is offline   Reply With Quote
Electrical Mystery quantumkyle Range Rover P38, Mk III and Range Rover Sport 8 09-28-2007 01:36 PM
Engine treatment - Mystery Oil me.guevara Discovery Series I 18 01-03-2007 02:10 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
1995 Range Rover Classic LWB w/ NEW engine Serg Land Rover Vehicles 3 11-21-2005 07:33 PM
1995 Range Rover Classic LWB Serg Land Rover Vehicles 7 05-04-2005 01:31 PM
