Old 05-23-2006, 08:34 PM   #1 (permalink)
Default '90 RRC Self Level System
Can you take the self leveling system out and "ditch it"? It looks like a big old heavy thing waiting to break.
Thanks.
J.B.
emmodg is offline   Reply With Quote
Old 05-23-2006, 09:11 PM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
You can take it out. But if it is actually working, you will have to upgrade your springs to take the extra weight that the self leveler normal takes. Taking it out will also affect you articulation off road, but the stiffer springs and the leveler out will improve on-road handling.
Ian
Old 05-23-2006, 09:42 PM   #3 (permalink)
Otherwise known as STEVE
I love the self-leveler... it works REALLY well and supports a lot of the weight of the truck without having harsh springs.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 05-24-2006, 07:31 AM   #4 (permalink)
If it ain't broke, don't replace it.
Old 05-24-2006, 04:30 PM   #5 (permalink)
yieldsign2's Avatar
Would the articulation be better or worse?
Devon Yablonski
1989 Range Rover Classic - Running and Muddy
1988 Range Rover Classic - Parts
http://ads.auctionads.com/pagead/lin...assZyieldsign2
yieldsign2 is offline   Reply With Quote
Old 05-24-2006, 05:11 PM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
Articulation is worse. Firstly the self leveler acts as a pivot point for your rear axle. This effectively forces the other wheel down when one goes up. It improves traction on the lower wheel and improves articulation. Secondly, it allows softer springs to be put on the outside. this allows the wheel to move more with the same weight transferance. Again improving articulation. The only time it retricts articulation is if you are going to go for a wild spring setup with dislocation cones, etc.
Ian
Old 05-24-2006, 09:16 PM   #7 (permalink)
RageRover's Avatar
I can tell mine used to have it, and was removed. However, the A arm on the rear diff is still there and attached to the axle.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 05-25-2006, 08:48 PM   #8 (permalink)
94 Defender 90
cellulararrest's Avatar
Only pre 1993 rovers with coil springs had the boge self leveling unit. Trucks with air suspension don't need it as the air suspension does its job.
It's almost guaranteed that these units aren't working anymore on any classic unless they've been replaced.
S.N.H.L.R.
cellulararrest is offline   Reply With Quote
Old 05-25-2006, 10:07 PM   #9 (permalink)
Rocky Mountain High
Funrover's Avatar
Well...took mine out a while back..WAS A GREAT MOD!! Better flex....and it was not working anyway!!
Old 05-26-2006, 06:26 AM   #10 (permalink)
A lot of them still work- in fact, most of them that come through the shop still work. They aren't 'overt' in how they work because when you load up the truck it will initially sag, then after a couple of blocks it will have equalized. Then when you unload, it'll sit high for a couple blocks and then lower. It's actually a very effective system. If you remove it, you REALLY need new springs. The spring rates on them are 30-45lb lower than a truck without the Boge unit.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 05-26-2006, 06:54 AM   #11 (permalink)
TerryS's Avatar
All NAS 110s had them too. Mine is still working just fine, and I wouldn't think of taking it out. An especially nice thing to have when fully loaded on the logging roads in Maine.
Old 12-26-2006, 05:18 PM   #12 (permalink)
campbell's Avatar
Dude,
Your truck is what I want mine to look like. I just bought a 95, and it looks like yours minus the upgrades. Where did you aquire your roof rack?
Nice Rover!
campbell is offline   Reply With Quote
Old 12-27-2006, 01:11 PM   #13 (permalink)
Where is my Black Son?
I wonder what is a sure way to find out whether or not it functions?
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler.
1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
MuddyRangeRover is offline   Reply With Quote
Old 12-27-2006, 02:04 PM   #14 (permalink)
i wanna know too
http://www.ThundaCats.com
dominick is offline   Reply With Quote
