My '92 Classic needs a radiator. New? Used? Rebuild?
How tough is installation?? Should I do a water pump at the same time? Where to purchase radiator, Rover North, Atlantic British?? THANKS |
You can have your radiator recored at a reputable radiator repair shop, it sure beats paying $500 for a new one. As for the H20 pump, if it's not leaking or making noise I would not replace it. As for removal of the radiator, it has two hold downs on each side on top, remove bolts, drain coolant, remove hoses and lift right out. Very simple operation. Good luck.
I agree with Lonestar.
It's easy to get to and get out just like he says. Have your local shop do a core. If it's too pricey try Rover Cannibal for a used one. Not sure of prices. I had my radiator rodded for $100(US) just this summer. |
If you can get it re cored.... then thats probably a good 3 year solution.. if you are going to keep it much longer than that then a new one may be in order. $500.00 is way too much to pay for one.. I got a larger 3 or 4 row radiator for $260.00 plus shipping for my 88 RR.. it had over 250k miles on the old one and there was no way to get it re cored.. For $260.00 its a small price to pay for keeping your engine cool...
My 2 cents
Any advice given in this forum is my 2 cents, which is roughly the value of said advice! Dan Hamren 93 LWB "Dubya" AKA "The Beast" |
a 3 or 4 row radiator will have a profile issue with the engine block.. i had an electric fan hooked up at the time, and the fan shroud had to be modified slightly...
Dan
