Old 06-09-2008, 10:36 PM   #1 (permalink)
Default 92 classsic Battery drain
I have a battery drain comming from my fuel pump fuse. anybody else had this problem, and what was the remedies? Thanks in advance
jwb1266 is offline   Reply With Quote
Old 06-10-2008, 09:21 AM   #2 (permalink)
ohiorover's Avatar
Check the EFI fuel relay under the passenger seat (square metallic five blade type), there's also the main relay on the left facing forward. Mine was buzzing a little and would sometimes blow the C4 fuel pump fuse on the dash or the 10A EFI fuel pump relay fuse under the seat. Atlantic Brirish has them for 30 bucks, I found one at auto zone for 5 bucks, they just have to match the plug pattern. I don't know if its a big difference, my 5 dollar relay hasn't given me any problems for 2 years. good luck.
ohiorover is offline   Reply With Quote
Old 06-12-2008, 02:02 PM   #3 (permalink)
I have my fingers crossed that your right, 2 new relays in the mail. We'll let you know how it goes
battery drain mystery wjones1396 Range Rover P38, Mk III and Range Rover Sport 0 05-28-2008 07:34 PM
mystery battery drain rockrover Range Rover Classic 15 04-13-2008 04:45 PM
Battery drain & upper radiator hose russdonna Discovery Series I 0 08-15-2007 11:39 AM
Battery Drain Kevin88RRC Range Rover Classic 6 07-01-2007 01:55 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
