Old 07-17-2005, 09:17 AM   #1 (permalink)
Default 93 classic-electronic problem-need help
My first post!!
While driving home yesterday the following electronics stopped working simultaneously:
seats
fan
horn
radio
clock
hazard lights(I checked them as I was troubleshooting)
Fan stopped working at all settings.
To note, the ignition key recently broke in the cylinder, I was able to start the car by using the broken half to turn the cylinder, but while it was running, all the same components didn't work. I took it to the shop and they were able to extract the key. Since then everything has been fine except that I was having problems with a defective battery(since replaced).
I have checked all the fuses in the box next to the radio. Are there others?
Right now I have the steering column open and I don't see anything disconnected.
Any suggestions would be greatly appreciated.
TB
TBLACKNYC is offline   Reply With Quote
Old 07-17-2005, 09:03 PM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
All those things (I pretty sure) are accessories and controled by the ignition switch. So you probably have a problem with that. Seeing as your key is busted off in there ... it only goes to reason you need a new ignition switch.
I punch my clown daily.
Old 07-17-2005, 09:26 PM   #3 (permalink)
Thanks OKIE,
I appreciate the input. Do you think that the key breaking in the switch would cause this or do you think it may have broken during the key extraction.
Time to start pricing....
Old 07-18-2005, 07:59 AM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
Who knows. Mine isn't broke but my radio and windows sometimes don't work. Can't wait to see my head lights go out while I'm tooling on a back road and hit a bump!
Old 07-18-2005, 08:18 AM   #5 (permalink)
4x4 Adventure Gear
John C's Avatar
Originally Posted by TBLACKNYC
Thanks OKIE,
Check grounds (one ground is on DS behind the cyl head, another one is on PS behind the battery).
I have an ignition and key from my 91 RR if you want to try it. Let me know.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
