Old 04-08-2007, 06:17 PM   #46 (permalink)
My bad on the nut/bolt issue. I had to spin 10, just not of the same type. If I could buy you a beer, well...
Turns out it was the main gear in the same axis as the drive shaft that broke in 3 places. Would that be the crown gear? And why would that let go?
I had to go with a 10 spline that was available close by due to time constraints (I have to be road worthy by Wednesday).
Bill
93 LWB Westminster 155+k miles
ArmyRover- "it's actually more of self inflicted torture chamber with doors and tires"- with this, I can relate!
O Crap! decals - $3.00 to your door.
Sign Guy is offline   Reply With Quote
Old 04-09-2007, 02:58 AM   #47 (permalink)
Ian Matthews
p76rangie's Avatar
Sign Guy, I hope that it had a 10 spline in it previously. You can't fit 10 spline axles to a 24 spline rear end and visa versa. The stub axles are different and the axles are different lengths.
Old 04-09-2007, 06:54 AM   #48 (permalink)
It has 10 splines, I was referring to Paul's offer on the 24 splines. Next time it goes I'll upgrade.
Bill
Old 04-10-2007, 07:57 PM   #49 (permalink)
Nomar's Avatar
Originally Posted by p76rangie
Nomar, my Rangie does have 24 spline in the rear and 10 spline in the front.
Did it come from Solihull that way?
The mere fact that a flame thrower even exists is proof that sometime, somewhere, somebody said to themselves, "You know, I'd like to set those people over there on fire, but I'm just not close enough to get the job done."
Nomar is offline   Reply With Quote
Old 04-10-2007, 11:31 PM   #50 (permalink)
Ian Matthews
p76rangie's Avatar
It would not surprise me if the factory had done it, but in this case I did it.
Changed the rear to a 24 spline centre so I could get slightly thicker axles.
Old 04-11-2007, 02:54 AM   #51 (permalink)
Changing over to 24 spline rears on older Range Rovers is pretty easy stuff. Doing the front is an entirely different matter. On my old truck, for example, it's easier to just swap in a complete axle assembly (best from a Disco) from rotor to rotor (then you also get nice vented rotors as well). I don't know when the change occurred but in doing the swap on my truck you also need the newer (post '87) radius arms as well (they're thicker at the axle casing). Things like the swivels mounting to the casing with seven bolts instead of six and a number of other small things make the switch a lot more complicated than simply changing hubs, flanges and half shafts.
Old 04-11-2007, 03:26 AM   #52 (permalink)
Ian Matthews
p76rangie's Avatar
I have only changed the centre to 24 spline. All the stub axles, etc are standard for the 10 spline set up. It is very easy to upgrade the front centre to 24 spline. As per the back of mine, there are after market axles that allow the conversion.
Old 04-11-2007, 08:09 AM   #53 (permalink)
What year is your truck and did it have ABS?
Old 04-11-2007, 08:17 AM   #54 (permalink)
Ian Matthews
p76rangie's Avatar
Mine is an 84 and no it does not have ABS. But for any 10 spline classic you can get axles from Maxi-drive that will run from a 24 spline centre to the CVs that run in a 10 spline diff.
Old 04-11-2007, 02:28 PM   #55 (permalink)
Nomar's Avatar
I changed one of my 91s(with ABS) to 24 spline ARB carriers. My other 91, a Hunter, (no ABS) is stock 10 spline............for now.
