Old 07-02-2008, 08:43 PM   #1 (permalink)
Default 93 RRC LWB - Wont Start
To top off an already crappy day, get home from the train and jump in the truck and it won't turn over. Battery is fully charged. Turn the key and lights on dash turn on, but wont turn over. Played with the shifter to make sure it was in park, even tried starting in neutral..... Nothing abnormal leading up to it. Any throughts?
Much oblidged.
christdj is offline   Reply With Quote
Old 07-02-2008, 09:20 PM   #2 (permalink)
roverthen's Avatar
when you turn the key, do you see the warning lamps on the dash come on? (oil, temp, Check engine, etc.)
I had the exact same thing happen and it turned out to be a fusible link in the engine compartment.
Abraham
1993 RRC LWB
I run, play, fix and live Rovers because I choose to.
roverthen is offline   Reply With Quote
Old 07-03-2008, 09:48 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
Does anything work?
I had ignition switch problems one lovely morning after I stopped at the 7-Eleven. Make sure the back of the ignition switch with the electrical bits is fitted to the lock mechanism. I've had mine fail twice in 6 years.
I punch my clown daily.
Old 07-04-2008, 05:11 PM   #4 (permalink)
Default answer is
Turns out that one of the leads to the starter solenoid had popped off. Who would have thunk. Plugged it back in and turned right on.
my disco wont start unknown Discovery Series I 5 04-01-2008 09:40 PM
Won't start till third turn of the key. crl Discovery Series II 2 02-21-2008 06:20 PM
No Start. Help I need to get to work. robbiewsmith Range Rover Classic 11 09-24-2006 10:21 PM
Engine Will not start MrSpool Discovery Series I 5 10-31-2005 01:48 PM
1995 Range Rover 4.0 Won't Start troverman Range Rover Classic 10 01-18-2005 06:33 AM
