Old 09-17-2006, 06:16 AM   #1 (permalink)
bargecapt
Default 94 classic cuts out going up-down a hill
guy i know has a 1994 classic 3.9, and he said that his truck will cutout-die when he goes up or down a slight grade, but will start right up. i had a mg midget years ago that would do the same thing when going around a curve, and it took me a good while to find the problem, it was a piece of hose from a gas pump that enedup in the fuel tank and would get sucked to the strainer.
he just had the fuel tank replaced (recall).
bargecapt is offline   Reply With Quote
Old 09-17-2006, 02:51 PM   #2 (permalink)
RageRover's Avatar
It could be the inertia switch for the fuel pump might be off set, or it is defective if it is sensitive to something that small of a change in angle.
Maybe the switch may need to be reset, just push the top of the switch under the hood on passenger side.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
