Old 01-03-2008, 03:45 PM   #1 (permalink)
Default 94 Classic LWB fuel problem?
My 1994 LWB Classic Rangie with 150k was going great until a couple days ago.
She would turn over fine and has spark. I listened closely to the fuel pump
and it was silent when I went to crank the engine. I pulled the fuel supply line from the fuel rail and cranked it over and nada, no fuel came out.
I swapped the relays, checked the inertia switch, no luck.
I just bought an entire new fuel pump from Atlantic/British and plugged it in to the wire harness to test it and it made not a sound.
Anyone have any ideas? I am kind of lost at this point.
thanks,
Mutator
mutator is offline   Reply With Quote
Old 01-03-2008, 03:46 PM   #2 (permalink)
Elemental's Avatar
Back to basics.
Did you check for power and ground at the pump?
When I was done with her, her bed needed Shamwow sheets!
Old 01-03-2008, 04:22 PM   #3 (permalink)
thanks for your reply Elemental.
yes - not getting power there. thought it was the relay.swapped it and no luck.
thought that after 150k i would need a new pump anyway.
what might the next suspect be?
Old 01-03-2008, 04:28 PM   #4 (permalink)
Elemental's Avatar
Confirm power and gorund at the relay. If the swicth and solnoid side both have power, you know your problem is between the relay and the pump.
If the solenoid power is missing, then you know your problem is between your ECU and Relay.
Old 01-04-2008, 03:17 PM   #5 (permalink)
okay, picked up a multi-meter & the CDROM manual. Unfortunately,
the CDROM manual DOES NOT run on my MAC! So I am in the dark with documentation until I buy a PC or the hardcopy manual.
ANYWAY, I replaced the fuel relay (blue connector base under passenger seat?) with a new relay, then I checked at the fuel pump with the multi-meter with the ignition key in the first click on position and measured + 4vdc at what I assume is power and ground. At this point, my battery was about dead so I have it on the charger now.
Does any of this sound promising? Should I be expecting to see +12vdc
at the connector?
thanks,
mutator
Old 01-04-2008, 03:21 PM   #6 (permalink)
Elemental's Avatar
You should be expecting Battery voltage, whatever that is at the time. If not running, that woudl be close to 12. 4 volts would make me think a corroded wire somewhere.
What color wires are you getting your reading from?
Old 01-05-2008, 11:03 AM   #7 (permalink)
regharged my battery overnite. now I am getting 5vdc on the black and green wires at the fuel pump.
the other pair white/purple and black show no voltage - is that pair for the
sender level?
sender seems to be working fine and reads level on the dash?
any chance that the ECU would step down the voltage or should it without question be around 12vdc?
thanks,
mutator
Old 01-05-2008, 12:26 PM   #8 (permalink)
checked the back of the blue base connector relay under passenger seat and finding 12vdc. but, i don't see any of the same color code wires there that i do at the fuel pump.
i find it really cumbersome to deal with all the electonics under the seats -
is there a better way?
also can't find the wire harness under the truck that leads to the tank.
(snow on the ground doesn't help)
Old 01-06-2008, 02:28 PM   #9 (permalink)
so it looks like white/purple is hot to the pump - well, I have 0 vdc on that.
all other wires to the pump/sender seem okay.
I took 12 vdc off my cig lighter to the pump and got her started and in my garage now. I guess I need to trace the white/purple wire and see what is up with it.
Anything come to light with this new detail?
regards,
Mutator
Old 01-06-2008, 10:33 PM   #10 (permalink)
repete's Avatar
after the relay you should have the inertia switch, then the pump. w/p wire from switch to the pump. have you checked that switch. under drivers seat
repete is offline   Reply With Quote
Old 01-07-2008, 05:44 AM   #11 (permalink)
Thanks Repete - I will trace from the inertia switch.
RR classic fuel filter Bryhn Range Rover Classic 0 08-13-2007 09:24 PM
Range Rover Classic Fuel Pumps OkieRover Tech & DIY 1 07-08-2007 10:08 AM
Fuel delivery problem MuddyRangeRover Range Rover Classic 1 05-09-2007 12:44 PM
92 V8i (Dual Fuel) - How to replace the fuel pump? AND an LPG problem... Please help! chrismillard Discovery Series I 3 05-01-2006 06:39 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
