My rover seems not to want to shift into 4wd. I haven't tried to force the stick, but it seems like it doesn't want to go forward. I've tried stopped, in "N" , rolling in "N" and so on, it doesn't seem to want to go no matter what I do. I got the truck from LA, CA back in December and haven't tried to put it in 4wd yet. I know, I know I should have done it. No telling how long it was before I got it (probably years). Otherwise, she seems happy. What gives? Can anyone point me to a existing thread? TIA.
1994 LWB County "L'Nard" |
I am confused by how you wrote your post. Your truck is ALWAYS in 4 wheel drive. It's a Land Rover. If it's just a problem between 4H and 4L then I can understand the question; but it seems like you are under the impression that you are driving around in 2wd???
"In certain places, at certain hours, gazing at the sea is dangerous. It is what looking at a woman sometimes is." - Victor Hugo Originally Posted by Elemental Some guys play hard to get, I play hard to want. |
Rebuilding Rover
Like XM said full time 4wd on these rigs.
Going on that I'll assume your stuck in 4 high and want to go into 4 low. If it hasn't been used in a long time the linkage could be froze up get underneath and clean and lube the linkage. Then try again. Linkage is located on the passenger side of the Rover if memory serves.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://www.wheelinrovers.com/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
My apologies - years of 4wd'in has conditioned me to think in terms of 2wd -4h and 4l - you are right though, the little lever that goes between 4h (where it stays for normal driving) and 4l seems to be frozen. Like unwilling to move at all. I have followed the instructions in the manual, it just seems to be stuck in place. Do these rust or corrode? I don't want to force the movement.
Rebuilding Rover
See above
94 Defender 90
Another thought... Just realized that '93 and up has the solenoid lock so you can't shift without being in neutral... I'd give this a read:
Range Rover Remedies |
#9 (permalink) |
Electrical failure in the interlock circuit is very common, but not as common as the linkage being frozen from lack of use. DON'T force it, the top bracket, an aluminum casting, breaks very easily.
| Thread Tools | |
| Display Modes | |
| Shift Indicator Assembly... | phyltered | General Land Rover Discussion | 0 | 04-19-2008 01:57 PM |
| manual shift and sport shift lights blinking? | deepsessions | Discovery Series II | 1 | 08-15-2007 04:45 AM |
| manual shift and sport shift lights blinking? | mnmike | Discovery Series II | 6 | 12-19-2006 08:38 AM |
| Gear Shift | OSIYEZA | Discovery Series II | 3 | 12-14-2006 12:30 PM |
| First - Second Shift Problem | OSIYEZA | Discovery Series II | 2 | 09-20-2006 04:04 AM |
