» Sponsors
» Sponsors
Old 06-16-2009, 09:45 PM   #1 (permalink)
Default 95 Classic Hot Starting problems.
Okay, a month or so ago, time flies when you are having fun, we had a code and replaced the right O2 sensor then the tach started sticking and we had some other problems. Replaced the alt, plugs (old plugs looked normal for old plugs), wires, rotor and cap and fuel filter (we had an acceleration problem that the fuel filter cured) and air filter and oil and filter, cleaned and checked the ground connections I could reach easily.
Cleaned and then replaced the IACV (aftermarket Chevy part) and it moves, the old one did not. Checked the ohms on the coolant temp sensor for the EFI and it is well within range on the three temps I checked. Cleaned the MAF with CRC MAF cleaner and checked for vacuum line and intake leaks.
Battery has some low cells as with a hygrometer (spelling?) but it cranks fine and starts fine cold, might be cranking a little longer than in years past? But not really sure on that...
Now the problem: A hot start from about five or ten minutes after shut down to about the bottom of the arc it cranks, sometimes fires, sometimes starts and shudders and in a minute or two will start running fine or die and then will not start until cooler as in about the bottom of the white arc on the gauge.
Today after cleaning and using dielectric grease on the EFI coolant temp sensor my wife went to town. After about five miles got a 14 code, coolant sensor EFI. Cleared it when my wife got home and ten minutes of running did not get it back.
Next guess in my opinion is the Ignition Amplifier (after looking for it I found it near the coil...). Going to check the connections and see what else I can think of. Saw some tests for the coil on the internet but I can not seem to find them again. Volts across during cranking? Replace the battery? Replace the coolant temp sensor for the EFI? No current codes but still not starting right hot! Going crazy...
'95 Classic, 4.2 LWB, 275,000 miles
sanmigmike is offline   Reply With Quote
Old 06-17-2009, 08:46 AM   #2 (permalink)
I went through a similar series of events that led me to do all that you have done plus replacing the coil and ignition module before curing it. Since then, all ok. Wait - I did also end up having to replace the intertia switch too as that then started affecting things when trying to get it going again. Was probably coincidence, but the module and coil are the only 2 items left you need to look at.
'95 RRC LWB (wife's DD), '95 RRC LWB parts truck
57loboy is offline   Reply With Quote
Old 06-17-2009, 10:53 AM   #3 (permalink)
Range Rover Freedom Fighter
BullDogSix's Avatar
Gallery: 7
Sounds like classic IAM (ignition amplifier module) issues from your description. If you want to relocate your IAM and upgrade to a GM part see this article: Solihull Society - Denver, Colorado » Blog Archive » Tech: Chevy Ignition Module Install
Also, here's a recent thread I discussed it on: IAM help!!
SI VIS PACEM, PARA BELLUM
"If you seek peace, prepare for war"
1994 RRC LWB, Cocked, Locked and ready to Rock!
BullDogSix is offline   Reply With Quote
Starting Problems 99 Disco II 4N4OUT Discovery Series II 1 12-17-2008 07:24 AM
starting problems yarraman1 Discovery Series I 2 09-24-2008 10:22 PM
Starting Problems w/ SIII CRASHCOUNT Series Land Rovers 14 01-28-2008 03:10 PM
RR Classic starting problems Najam uz zaman Range Rover Classic 2 08-11-2006 10:21 AM
1993 Range Rover starting problems JButcher Range Rover Classic 14 09-14-2004 10:07 PM
