Old 01-10-2008, 01:04 PM   #1 (permalink)
CLASSICRR
ROVERKRAZED's Avatar
Default 95 County Classic Radio Wiring
DOES ANYONE KNOW OR HAVE RDIO WIRING DIAGRAMS ,SCHEMATICS AND OR COLOR CODES FOR WIRES.IM TRYING TO UPGRADE STEREO AND CANT SEEM TO FIND THIS INFO.SO BEFORE I START CUTTING WIRES JUST WONDERING IF ANYONE COULD HELP
ROVERKRAZED is offline   Reply With Quote
Old 01-10-2008, 07:29 PM   #2 (permalink)
hermanpj's Avatar
Gallery: 4
i have a 1991 Classic which is before the softdash, so wiring harness could be different. i think 1995 had a different head unit as well... so this may or may not work for your truck. but i happen to have my wiring diagram out. So this is a list of wiring for the head unit in a 1991 Classic:
Color Key
B Black
K Pink
N Brown
S Slate (whatever that is)
W White
G Green
L Light
O Orange
U Blue
Y Yellow
The following are the colors of wiring and purposes I derived from the wiring diagram. Some of these individually connect, some are in a pigtail/connector.
B - Ground
Data Link Cable = to CD player
LG - power, connecting rear amp, front amp, head unit and fuse panel
PW - power connecting head unit, cd player, and fuse panel
RN - connects to rheostat, I belive this is panel dimmer rheo
PY - Connects head unit, front amp, rear amp, i believe this is remote control to turn amps on and off
BW - speaker - front amp - Right +
BN - speaker - front amp - Right (-)
BU - speaker - front amp - Left (-)
BG - speaker - front amp - Left, +
Red & White - should be in "Screened Cable" - Audio Inputs to Rear Amp
W - Rear Right
R - Rear Left
Before using this as key, you should be sure the 1995 doesnt have different wiring scheme.
Pat Herman
Old 01-11-2008, 12:22 PM   #3 (permalink)
CLASSICRR
Thanks But It Seems That My Wiring Is Different , I Cant Seem To Find A Front Amp And Some Of The Colors Dont Match
Old 01-11-2008, 07:54 PM   #4 (permalink)
visit a radio install shop or best buy or even circuit city installation dept, they should have the connector interface so you dont have to cut your wires, that way you simply plug and play.
carlosz is offline   Reply With Quote
Old 03-11-2008, 08:51 PM   #5 (permalink)
CLASSICRR
Thanks Guys For The Input Ended Up Cutting And Rewiring The Whole System Even Added 6.5 Speakers To Rear Doors,new Amp And New Speakers All Around,new Sub And Sub Box
County Classic TWR SWB jugganuat Land Rover Parts and Vehicles Wanted 0 05-04-2007 01:03 AM
95 RR Classic LWB Radio Removal AdrianL Range Rover Classic 1 02-13-2005 03:38 AM
95 disco radio wiring diagram GentrysRover Discovery Series I 0 01-24-2005 06:22 PM
94 Discovery Radio Wiring Brian Z Discovery Series I 1 01-17-2005 03:39 PM
Radio wiring diagram needed Rick Lindsay Discovery Series I 0 11-28-2004 06:51 PM
