Old 03-03-2007, 08:37 PM   #1 (permalink)
my name is Todd, and I'm a rovaholic
TooSlowMonroe's Avatar
Default 95 LWB- New Rotors and such
So...while in the dealers for my leaking seal, I'm told the rear brakes are shot and I need rotors and pads. Yeah, yeah, yeah...so I decide the dealer has had enough of my cash and I'm gonna do this myself.
Rear brakes are now done. New, Upgraded rotors and pads on the rear. Have a bad caliper that will be replaced as soon as the new one arrives, then I should be ready to go.
The front are basically new, spec'd out about 10% less that new...so I'll leave them for now. Question for you guys: How hard are those front rotors to replace compared with the rear. My first time doing anything like this, and I've never worked on a 4WD or FWD, so I've never had to pull rotors with the CVs in them...is this gonna kick my butt?
Thanks,
Too Slow
'05 Scion xB
'91 Mercedes 300SE
'95 Range Rover Classic LWB
'60 Ford F-250
'78 Ranger20 Sailboat
'71 Melges M-20 Scow Sailboat
TRY? There is no TRY. There is DO and DO NOT.
-yoda
TooSlowMonroe is offline   Reply With Quote
Old 03-03-2007, 09:10 PM   #2 (permalink)
KevinNY's Avatar
Same as the back, easy. Unbolt caliper and move out of the way, remove drive flanges, remove hub, unbolt old rotor (place it in the wheel you removed to keep it from spinning away from the wrench), clean mating surfaces, degrease caliper bolts, and rebolt caliper to hub and torque to spec with blue loctite. Slap it back together and take the opportunity to clean out and repack your bearings.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
KevinNY is offline   Reply With Quote
Old 03-03-2007, 09:25 PM   #3 (permalink)
Awesome...thanks Kevin...I think I can handle the fronts now when the time comes due...I appreciate the response.
'05 Scion xB
'91 Mercedes 300SE
'60 Ford F-250
-yoda
Old 03-04-2007, 01:55 AM   #4 (permalink)
RageRover's Avatar
Yeah, the front brakes are relatively easy, just hub style, but this case the hub is removable, otherwise hub rotors for our trucks would be outrageously expensive.
And Kevin, nice idea trick with putting the hub into the wheel to make removing the rotor-to-hub bolts easy. I will keep that in mind later down the road.
BTW Todd, I dig those cross drilled rotors!
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 03-04-2007, 04:55 AM   #5 (permalink)
series1rangie's Avatar
looking good, you will find that the fronts are as straight forward as the rear. Seeing your shop floor, i am so jealous, curently rebuilding my swivel balls, and the yard is getting pretty messy. will post a pick so all can laugh.
'81 RR 2dr "Miles"
'89 RR 4dr parts
'96 VW Jetta the driver
series1rangie is offline   Reply With Quote
Old 03-04-2007, 08:26 AM   #6 (permalink)
LOL...thanks for the replies. Mike...can't wait to see the pics...
'05 Scion xB
'91 Mercedes 300SE
'60 Ford F-250
-yoda
Old 03-04-2007, 12:37 PM   #7 (permalink)
Where is my Black Son?
I was advised "not' to run drilled/slotted rotor on a rig being used for offroading, due to mud building up and reducing their effectiveness.
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler.
1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
MuddyRangeRover is offline   Reply With Quote
Old 03-04-2007, 04:37 PM   #8 (permalink)
Muddy...I've heard the same thing. If I ever got in so much mud that it was caking in my brake rotors, I think I'd have much more to worry about...LOL. Actually, where I am, there is not that much serious mud to worry about, I tend to shy away if it's more than a few inches.
'05 Scion xB
'91 Mercedes 300SE
'60 Ford F-250
-yoda
