Old 01-14-2005, 04:41 PM   #1 (permalink)
Question 95 LWB Programming Remote... Help!
Ok..... I've seen the postings that explain how to program a 1-button key fob remote WHEN ONE HAS ANOTHER PROGRAMMED REMOTE. But I don't have a programmed remote; I only have my key and a new unprogrammed remote.
Can anyone tell me how to program a new remote for my 95 LWB without the benefit of a programmed remote.
Thanks!
Roving Westward is offline   Reply With Quote
Old 01-14-2005, 06:28 PM   #2 (permalink)
yo mama
Jonesy's Avatar
TWO PERSON JOB:
  1. Open hood have assist hold in the hood button (left side as you look in)
  2. ensure on the inside all doors closed, ignition off all locks UP
  3. turn ignition on then off
  4. push the driver side door lock down then up
  5. assist then releases hood button
  6. turn ignition on then off
  7. if done correctly (within 15-20 secs) horn will beep once dash LED will light up - then learn mode is accesed - IF IT DOESN'T WORK - keep doing it only quicker!!!!!
  8. after it works - pusha nd hold remote the dash LED will flash 8 cycles a second for 1 sec to show the code was received IF IT DOES NOT HAPPEN - repeat 1-6 again...QUICKER!
THAT IS IT - NOTE YA NEED TO DO 1-6 QUICK!!!!
Jonesy is offline   Reply With Quote
Old 01-14-2005, 06:33 PM   #3 (permalink)
LRO Founder
Serg's Avatar
Yep... that's what I did with mine.. my 95 LWB came without a remote. I bought on on eBay and did this procedure and it worked fine.
Serg
Current Vehicles:
2003 BMW 540iT M Sport
2005 BMW R1200GS
2004 Element Skateboard (Indy trucks, Bones Swiss, etc...)
Past LR's:
1995 Range Rover LWB Classic
1997 Discovery XD
1995 Range Rover LWB Classic 4.0
Serg is offline   Reply With Quote
Old 02-02-2007, 10:09 PM   #4 (permalink)
Default Serg
Serg,
Do you remember what seller you got the keyless entry from? I looked tonight on Ebay and did not see the one I have (95 classic).
Thanks
Sam
boxer is offline   Reply With Quote
