My 95 LWB decided not to turn over today. Every once in a while it will catch and start up, but after a few seconds it dies again. I have no idea what to start with in terms of a fix. My service engine light went on a couple of days ago, but I have not brought it into my mechanic to see what codes might need attention. I have 180K on the clock.
Any ideas? Thanks. |
at some point it will break . . . and I will ATTEMPT to fix it!!
Is the starter just turning over, or is it doing nothing at all???
If it's turning over, move on to the next possibility. If not, focus on the starter and related components. Have you tested to see if you are getting spark at the plugs?? Remove a plug wire, stick a screwdriver in the connection for the plug on the wire, and have a friend turn it over. Does it spark??? The coil might be crapping out as well so check that. Are you getting fuel to the injectors??? No fuel could be numerous things. Check the fuel filter as well. If it's full of crap and debris, replace it. Check the fuel pump as well. Is it turning on??? What about timing??? Is your RRC in need of some maintainence/timing adjustment. 180K is alot of miles, but it may be due for scheduled maintainence. Get the Check Engine code first, then start to eliminate problems one by one. You can pull the code yourself, just do a search for the procedure. $.02 to get you started, keep us informed.
1991 Mitsubishi Galant VR4 717/2000Arias Pistons/Eagle Rods, '94 Talon Tranny -Fun as hell, always broken 1986 Chevy K20 AKA White Lightning 350, 4 Speed, 3" Lift, 32" Maxxis Buckshot Mudders-Never broken, always out of gas 1995 Range Rover CountyLWB AKA Darth Vader,K&N air filter, coil spring conversion, Maxxis Bighorn Mudders -The ULTIMATE TAOS VEHICLE
| Thread Tools | |
| Display Modes | |
| Key Wont Turn | Disco 1 | Discovery Series I | 4 | 05-15-2008 07:25 AM |
| Turn Signal Problem | nate13 | Discovery Series I | 8 | 04-27-2008 06:43 AM |
| Key - difficult to turn in ignition (starting and turning off) | mm_putnam@yahoo.com | Range Rover Classic | 3 | 11-10-2007 05:21 AM |
| P38 ..Non-Starter!! | Fozzy | Range Rover P38, Mk III and Range Rover Sport | 25 | 04-12-2006 03:50 AM |
| 99 4.6 is superlocked and won't reset | Spring | Range Rover P38, Mk III and Range Rover Sport | 9 | 12-05-2005 04:46 PM |
