Old 05-23-2008, 09:20 AM   #1 (permalink)
Default 96 RR front oil leak
Hello everyone,
I just bought a 1996 Range Rover with 147,000 mi on it for, $5600. The owner paid up to $200 to help with the oil leak problem but all that repair did was slow the leak to almost nothing. The repair shop specializes in Rover so I trust thwy know what they are doing.
The repair man said the oil is coming from a 'pulley' in the front of the RR, I've never heard of anything like this, but then again I've never owned a rover. He replaced the gasket on this 'pulley' and said it should fix the problem, but 2 days after the repair, the oil started to drop again, a lot less than before though. Maybe 2 drops over night. I'd like to have 0 drops. Any ideas?
JHall
ps: he said a belt was lose that he tightened as well.
sobehall is offline   Reply With Quote
Old 05-23-2008, 11:11 AM   #2 (permalink)
Roverholic
lsawicki's Avatar
Gallery: 9
Well, as long as it's nothing bad, I wouldn't be too worried. Range Rovers are British cars, and for some reason, the brits haven't mastered the whole gasket/valve thing. If it helps, I have a power steering leak (like almost every other classic!). If I was me, I would forget about the drops of oil and start saving for the next thing that will go wrong =)
lsawicki is offline   Reply With Quote
Old 05-23-2008, 11:21 AM   #3 (permalink)
hermanpj's Avatar
Gallery: 4
put a rubber mat down in your garage where it leaks! i agree - its just hard to get these trucks to '0 leaks'
Pat Herman
Old 05-25-2008, 01:06 PM   #4 (permalink)
Rover Junkie
GDEclassic's Avatar
its not a leak. Its rust protection. I agree, put down some cardboard and watch your fluid levels.
Denver Colorado
-1991 Great Divide Edition Range Rover Classic-
-2000 Audi S4
GDEclassic is offline   Reply With Quote
Old 05-28-2008, 09:14 AM   #5 (permalink)
1998 Range Rover
I had the same problem on my 98....the front main seal or crank seal is what your mechanic probably replaced... Mine is leaking too, however if you just had it replaced, theres a good chance it is the front cover seal...which i now have to replace on mine
roverbryan08 is offline   Reply With Quote
This Locker or that Locker xd97disco Accessories 368 07-08-2008 09:15 AM
Range rover P38 weird Oil leak problem pat3d Range Rover P38, Mk III and Range Rover Sport 12 04-26-2008 07:56 AM
What's up with that rover oil leak thing??? Steph Discovery Series II 16 09-02-2007 11:37 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 10:41 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
