Old 02-16-2007, 04:25 PM   #1 (permalink)
Default ABS pump noise/bleeding
I just installed a new ABS pump and relays. The accumulator was replced before that because i originally thought that was the problem. Now the pump stays on and makes a weird noise. It gets louder at times then gets softer. It sounds like there is air inside. How do i bleed the abs pump and or the master cylinder. I bled the brake on the wheels but im ont sure if i did them correctly. Should I just keep bleeding the brakes untill the noise stops? Any help would be appreciated.
-Mark
mdvickst is offline   Reply With Quote
Old 02-16-2007, 04:54 PM   #2 (permalink)
sven's Avatar
Brake Problems 95 RR 4.2 V-8
99 D1
73 Series SWB
95 RRC LWB - Sold
