Old 04-09-2008, 05:42 PM   #1 (permalink)
Default Abs Pump / Relay issue
So my ABS pump is making odd noises and running after the rover is shut off. I know the first thing to replace is the relay. ( 1991 rover lwb) Is it just 1 relay? I searched a year or two earlier post that state they found the 30A circuit under the driver seat. Is THAT the relay? Do i need to spend $35 bucks for them on dap inc OR is there an alternative replacement?
tre976 is offline   Reply With Quote
Old 04-10-2008, 09:00 AM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
That's the one. I've tried to find alternatives but it is a pretty important relay considering the cost of the pump if it fails.
I punch my clown daily.
Old 04-15-2008, 08:29 PM   #3 (permalink)
are the relays housed in the ecu under the driver seat?
Old 05-04-2008, 09:26 AM   #4 (permalink)
ohiorover's Avatar
They are under the drivers seat door side, just remove the two seat base covers. On the 1992 it goes left to right, blue relay-three fuses- black relay-black relay(this is the pump relay)- giant 30amp fuse
ohiorover is offline   Reply With Quote
Old 05-04-2008, 09:30 AM   #5 (permalink)
ohiorover's Avatar
While we are on the topic, I sometimes get a pulsing from my brakes, its not the rotors, something in the ABS or vacuum sensor. I checked the speed sensors and rotors, no codes from the brake ecu. Comes and goes, better if i pull the relays and reset the thing. ideas, 1992 county
hard start/fuel pump relay armydisco Discovery Series II 13 05-04-2007 02:39 PM
Window Relay/ Steering Pump Jery Range Rover Classic 4 03-31-2007 01:15 AM
HELP!! Fuel Pump??? Truck still on trail. bluemax09 Discovery Series I 14 02-22-2006 03:40 PM
Disco 1 Fuel Pump + Fuel Pump Relay Toddicus Land Rover Parts and Accessories 1 10-11-2005 08:10 PM
Disco 1 Fuel Pump + Fuel Pump Relay Toddicus Land Rover Parts and Accessories 0 11-24-2004 12:42 AM
