Old 12-09-2007, 03:27 PM   #1 (permalink)
atvsmurf's Avatar
Default After market gauges install question...
I will be installing some gauges in my truck, has anyone else done this, and where did you mount the sending units for the oil pressure and water temp?
atvsmurf is offline   Reply With Quote
Old 12-10-2007, 07:59 PM   #2 (permalink)
I ran "T" connectors on mine, the oil is at the pump just before the oil pressure switch. the water is on one of the heater lines, after all they run coolant from the block before the thermostat so even if the thermostat fails shut you do get actual temp.
carlosz is offline   Reply With Quote
Detailing 101: Common Question and Answers, What and Where to buy stuff + Technique David General Land Rover Discussion 52 08-23-2008 11:36 AM
ABar question DiscoSE03 Discovery Series II 5 03-27-2006 06:29 PM
Fog light install on Chrome bumper part AdrianL Range Rover Classic 0 09-21-2005 12:43 PM
Running boards & nerf bar Install Question GentrysRover Accessories 0 06-28-2005 06:16 PM
New Question concerning ACE install Phlawed Off Road 1 06-18-2005 01:18 AM
