I know this is a common topic but I have a 89 classic and I will have rover tym 3" springs and 2 inch spacers. I am also planning on cutting the fenders to remove the lip around the wheel wells. this should give me enough clearance for a large tire. hope fully a 36 or 37. But the biggest problem is that I am not sure what axles to switch to. I could bolt disco axles in for pretty cheap and then build them up. Or I could put dana 60's under it from a junk yard. I could do all the fab work myself confidently unless I had to change the tube lengths. I wouldn't have a problem with the tire sticking out the sides a couple inches. has anyone done this or running a 37 inch tire on a rover axle?
I'd just stay with a 35" tire with that combo, much easier build. For 37s I would think you would want to go to Toyota centers and 4.88s.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc. '91 RRC, bone stock |
X2! 35's. GBR HD front and rear, with 4.11's, or 4.75's. If you go bigger than that, run your axle tubes, but fo the toyota third member conversion, and rovertracks components.
"In certain places, at certain hours, gazing at the sea is dangerous. It is what looking at a woman sometimes is." - Victor Hugo Originally Posted by Elemental Some guys play hard to get, I play hard to want. |
#9 (permalink) |
Maxi drive Axles and CV's and a locker is all you'd need for a plenty strong setup, why ruin a Rover with Toymota Landloser bits.
Smoke me a Kipper, i'll be back for breakfast! |
#10 (permalink) |
Ian Matthews
We have had this debate before, but you do not generally need stronger axles due to tyre size. When you need them is when you change things like the diff ratios due to the tyre size.
Toyota centres are not going to change the strength of the axles or CVs. Toyota centres are usually used where you want a greater selection of diff ratios or you have problems with breaking crownwheel and pinions. Just upgrade your axles. Maxidrive make HD axles that will fit 10 spline centres. They are more than strong enough for most purposes. |
#11 (permalink) |
jimfoo
Well if you are going with that tire size, you will almost have to change diff ratios. Then you will have to upgrade axles. Your carrier is weak with only 1 cross pin, so that will eventually break as well. The other thing is what kind of off-roading do you do? Lots of rock crawling would need a stronger axle than loose dirt and mud.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
#12 (permalink) |
1 cross pin? How the hell would a carrier have only 1? I thought they were 2 or 4. I don't even think it would be possible to engineer one with only 1.
#13 (permalink) |
jimfoo
Well, it's one long pin that goes through 2 gears, so yes, it is 1 pin technically, but I guess considered 2 as far as function goes.
#15 (permalink) | |
Ian Matthews
| Thread Tools | |
| Display Modes | |
| spline count on rrc's..... | daway | Range Rover Classic | 8 | 06-29-2007 07:37 PM |
| HD front axles and CV's | KevinNY | Land Rover Parts and Accessories | 3 | 01-02-2007 10:38 AM |
| VC's, CDL's, and some locker stuff too! | nfrey2 | Range Rover Classic | 7 | 03-03-2006 06:47 PM |
| Special oil for axles ? | imag | Discovery Series II | 4 | 09-29-2005 01:36 PM |
| question about heavy duty axles and spline count | MathewBGoode | General Land Rover Discussion | 0 | 07-24-2005 03:37 AM |
