Old 01-27-2008, 12:53 PM   #1 (permalink)
Default B/w 1361
The Rangie's 3.9 is calling it quits. With a terminal oiling problem, several leaks that need attention and its numerous other "small issues", I have discovered that a particular engine swap will be more cost effective both in the short run and in the long run. However in order for this to happen, I need to know if any of you guys know the input shaft diameter and the spline count/depth of our Borg Warner 1361 transfer cases. Exhaustive searches online for this information have yielded no information of any real use. Someone here has to know....
Jroc81 is offline   Reply With Quote
Old 01-28-2008, 10:24 PM   #2 (permalink)
Someone has to know...
Old 01-29-2008, 02:00 PM   #3 (permalink)
XtremeMarine's Avatar
Post this question on the Land Rover thread of Pirate 4x4, and you'll have an answer within a couple of hours.
Old 01-29-2008, 07:35 PM   #4 (permalink)
hermanpj's Avatar
Gallery: 4
sounds like you might be thinking of putting a non rover engine and transmission in...
do tell.
Pat Herman
Old 01-29-2008, 09:05 PM   #5 (permalink)
After a lot of thought, and a lot of time spent looking at gas prices, I decided to go for the Gm 6.2l diesel. Marks 4x4 in Australia makes a gm smallblock swap kit for RR's consisting of an adapter plate. engine mounts, and a few other odds and ends, However, the entire kit, minus the engine will run you about 900 dollars shipped to your door. In the long run, it's much cheaper to buy a 6.2l diesel and a 700r4 and just fab some mounts to make it fit perfectly. I know that 700r4's had either a 27(early) or 32(late) spline output shaft. This combo was typically mated to an Np 208 t-case, in Gm trucks, which is rumored to have the same input shaft dimensions as the B/W 1361, aka our t-cases. The purpose of this thread is to find out if that rumor is true, so that I can source the correct 700r4 for the project. I'd hoped someone on here had that information...
Old 01-30-2008, 06:20 AM   #6 (permalink)
hermanpj's Avatar
Gallery: 4
call atlantic british, tell them you may or may not have to buy a new transfer case and you need to know this info. they might be able to tell you. worth a phone call anyway.
Pat Herman
Old 01-30-2008, 06:35 AM   #7 (permalink)
RRC Owner in training
BullDogSix's Avatar
Gallery: 2
You could also contact Advance Adapters.Com Engine & Transmission Conversion Adapters...they make all kinds of engine/trans/tcase adapter combos, but they are also a great source for info.
BullDogSix is offline   Reply With Quote
Old 01-30-2008, 12:23 PM   #8 (permalink)
odlsmobile sierra and or cuttlas calaiss had front wheel drive and came in 4d or s/w configuration and a number of those came in diesel configurations V6 to be exact. that
should give you good performance and keep the weight down since the 6.2 v8 is almost 800 lbs. if you decide to go with the v8 you would have to really beef up your front springs, keep in mind that your differentials are off set so in using a different t case which may have non off set rear out-put, you will bind the rear yoke when articulating offroad and thus causing catastrophic damage..... Ihave seen it before.
carlosz is offline   Reply With Quote
Old 01-31-2008, 03:17 AM   #9 (permalink)
the t -case is remaining intact, in place. Don't worry, I wouldn't think of putting a 6.2 in there without upgrading springs
Old 02-02-2008, 08:44 AM   #10 (permalink)
Three days on pirate4x4 and not one reply... Have I secretly asked for the meaning of life? Or the location of the holy grail?
Old 02-02-2008, 08:47 AM   #11 (permalink)
I gave them a call. They knew less about our t-cases than I did. The directions they pointed me in where the ones i tried before posting this. Things aren't looking too good
Old 02-02-2008, 09:43 AM   #12 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I'd just pull the transfer case and measure it up myself if I were you. Your going to need to pull it anyways during the swap.
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 02-02-2008, 08:17 PM   #13 (permalink)
True, but if the answer can be had, by merely asking, wouldn't you?
Old 02-02-2008, 08:34 PM   #14 (permalink)
BullDogSix's Avatar
Gallery: 2
I'll be pulling my T-case and Tranny this month for replacement...if you can wait, I will measure it up while is out.
Old 02-03-2008, 06:26 AM   #15 (permalink)
that, would be awesome sir
