Old 06-22-2007, 01:01 PM   #1 (permalink)
Default backfire through intake
This only happens over half throttle. The engine cuts out and starts popping, no codes. Any ideas? Thanks
1990 RRC colorado silver, tan leather all stock
Gotroxblazer is offline   Reply With Quote
Old 06-22-2007, 05:55 PM   #2 (permalink)
DaKeG's Avatar
I have noticed the same thing that happens to me when I let is sit for a while. By a while I mean around 2 to 4 weeks. I also noticed that my idle was off. I adjusted my idle to around 600 - 700 in gear at a stop. That seemed to help. I should check my timming though.
DaKeG is offline   Reply With Quote
Old 06-22-2007, 06:54 PM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
Put a good dose of injector or petrol cleaner through the engine. Backfire can be caused by carbon build up in the cylinders. May not be the cause, but it won't do the engine any harm and you can cross one of the list.
p76rangie is online now   Reply With Quote
Old 06-27-2007, 04:21 PM   #4 (permalink)
what about something in the ignition system?
Old 06-28-2007, 02:03 AM   #5 (permalink)
Ian Matthews
p76rangie's Avatar
It could be something in the ignition, but it is often related to other things. For example the engine running too lean. It can also be valves.
But a backfire is different to popping. In the heading of the thread you start that it is a backfire, but the text states that it is a popping.
Does it go bang, or just it just start missing.
Old 06-28-2007, 02:34 PM   #6 (permalink)
It cuts out, and if you keep in the throttle, it pops back through the intake like it's trying to run, but can't. If you let off throttle, it returns to idle and idles fine.
