Old 01-15-2006, 03:08 PM   #1 (permalink)
CurvyRover's Avatar
Default Bad Mechanic
I went out to check out my rover this morning since it didn't come back fixed from the mechanic - he said it started and ran just fine, but it doesn't. I found 1 wire completely disconnected from the cap and sitting 1/2 way underneath the cap. I had to take the cap off to get it unstuck and in the process another wire came off and I can't get it to connect on the cap now so it's just sitting there. I also found two little wires disconnected from each other and have no idea which goes to which.
I took photo's that y'all can see at http://curvyrover.blogspot.com/
Can anyone tell me from the photo with the disconnected wires which one hooks to which?
Thanks to y'all I now know what's wrong with it and am in the process of hunting up and purchasing the parts that I need. I also called another mechanic here in my town who has worked on a couple of classic RR's and he said that he can do the work for me.
I'm still so shocked from the outcome with this past mechanic that I haven't yet reached angry. Has anyone else ever had this sort of thing happen to them? I wasn't pushy or bitchy, I didn't even get angry with him when he said he would call me back a few times and didn't. Should I have been a bitch then?
Stuck-N-Texas
CurvyRover is offline   Reply With Quote
Old 01-15-2006, 07:22 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
That is crap that he didn't even put it back together to the same condition it was....When I was a mechanic working on motorhomes I would have got in big trouble for that!!
Old 01-16-2006, 06:27 AM   #3 (permalink)
Wires on your bottom picture don't connect to anything, thats the way they are on my RR. The loose wire on the dizzy should be connected, you should be able to snap it in.
lonestarrover is offline   Reply With Quote
Old 01-17-2006, 08:54 AM   #4 (permalink)
CurvyRover's Avatar
I put the loose wire back on, but the other wire is just sitting there - UGH!!!
When I replace the distributor, should I also replace the cap and rotor (again)?
And can someone tell me which mallory distributor - the 18 degree or the 24 degree? What is the difference between the two?
Stuck-N-Texas
Old 01-17-2006, 05:03 PM   #5 (permalink)
DISCO INCUBUS's Avatar
Wink
I asked the same question in another thread and got no response, must be top secret info ?
Only thing chrome on my truck are me balls
DISCO INCUBUS is offline   Reply With Quote
