» Sponsors
» Sponsors
Old 07-03-2009, 09:10 AM   #1 (permalink)
hermanpj's Avatar
Gallery: 4
Default battery cut-off switch - instructions?
I bought a heavy duty battery cut-off switch - the simple kind with the big red key. anyway, it didn't come with instructions. Has anyone mounted one of these and if so have instructions. i can guess the cutoff switch should mount between the battery ground post and the ground cable, but a pic or description of what to mount it to would be helpful. thanks
Pat Herman
Old 07-03-2009, 11:01 AM   #2 (permalink)
OldnDirty's Avatar
My RRC had one in it when I bought it. The PO installed it in the passenger side inner fender, near the battery. You just cut the main battery ground cable, solder ring terminals on the cable ends, and attach those ring terminals to the switch. All you are doing is making a break in the ground circuit with the switch. Hope that helps.
Lord grant me the serenity to accept the people I cannot shoot
The courage to shoot the ones I can
And the wisdom to know the difference
-Shea's serenity prayer
OldnDirty is offline   Reply With Quote
Old 07-03-2009, 07:39 PM   #3 (permalink)
hermanpj's Avatar
Gallery: 4
thanks dude.
Pat Herman
Old 07-03-2009, 08:55 PM   #4 (permalink)
mbrummal's Avatar
I thought you would put it on the positive side. Well, either way disconnects the battery so it won't die from parasitic loads.
This site sucks balls.
mbrummal is online now   Reply With Quote
Old 07-09-2009, 08:06 PM   #5 (permalink)
hermanpj's Avatar
Gallery: 4
does anyone have knowledge whether it should be on positive or negative side?
Pat Herman
Old 07-09-2009, 08:09 PM   #6 (permalink)
Deployed OIF
ArmyRover's Avatar
I had always done it on the positive cable.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Old 07-09-2009, 09:40 PM   #7 (permalink)
OldnDirty's Avatar
Mine is on the negative side. It doesn't really matter as long as you're breaking the circuit. Mine was done before I bought it. If I were to do it myself, I would probably do it on the positive side now that I think about it.
Old 07-10-2009, 05:58 AM   #8 (permalink)
Rineheitzgabot's Avatar
I just installed one a couple of weeks ago on my Series. I put it on the positive cable.
If you want, I can post some pics when I get home.
-Gary
Rineheitzgabot is offline   Reply With Quote
Old 07-10-2009, 09:30 AM   #9 (permalink)
lwbblue's Avatar
pat,
this is not a nonchalant issue! It must be installed on the positive side. Most race cars have the switch you are talking about, and at technical inspection it is always checked to show that when it is off there is not juice running through the wires looking for a ground. The big example is; the battery cable connects directly to the starter. Mount the switch on the ground side then poke around the starter with a wrench, good way to burn your finger off. Mount it on the hot side for safety and live with punching in the radio code each time.
good luck geneo
lwbblue is offline   Reply With Quote
Old 07-10-2009, 09:59 AM   #10 (permalink)
antichrist's Avatar
How you mount it really depends on what your goal with the switch is.
Please explain how you get any arching at the starter when the ground post on the battery is part of the circuit.
On race cars I could see it wanting to be on the pos since in a wreck the ground post of the battery could be in contact with crunched metal and thus complete a circuit.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 07-11-2009, 08:20 PM   #11 (permalink)
hermanpj's Avatar
Gallery: 4
reinnheitsgebot, please post a pic im interested what you anchored the switch to.
AC, my goal with this switch is to better preserve battery and insulate it from parasitic drain.
thanks, Army.
Pat Herman
Old 07-12-2009, 07:47 PM   #12 (permalink)
thanks, Army.
Hope this helps:
Picasa Web Albums - Garrick
I had a 5-wire plug used for towing there, that was obsolete, so I used it as the mounting hole for the switch.
Old 07-13-2009, 06:05 AM   #13 (permalink)
antichrist's Avatar
Then it doesn't matter if it's on the Neg or Pos.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 07-14-2009, 10:37 PM   #14 (permalink)
ECU needs current !!!!
The battery cutoff is just that ! Its main function is to close all electrical contacts in a crash or other emergency situations. Either (-) side or (+) side as long as you have severed the connection.
Now if you have a drain , the cutoff will only mask the problem, but its not a fix,and you can create more problems with the ecu and or alarm systems.
Find the drain first !
Populus is offline   Reply With Quote
Old 07-15-2009, 06:26 AM   #15 (permalink)
Been there, Broke that
It goes on the positive side... why do you think the switch and key is red? the goal is to keep current from getting to anything. just because you interrupt the ground side of the battery doesn't mean there isn't power flowing anymore.
but, like populus said... Find the problem of what its doing.
1991 RRC Great Divide Edition #245
Divied245 is offline   Reply With Quote
Update: No Start BullDogSix Range Rover Classic 5 01-18-2009 06:36 PM
Door not unlocking with key problem bruinfan90241 Range Rover P38, Mk III and Range Rover Sport 3 03-15-2007 02:12 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 05:46 PM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 10:06 PM
SEO by vBSEO 3.3.2
