Old 12-01-2007, 01:12 PM   #1 (permalink)
1990 RRC
gregory.pearson's Avatar
Default Battery Drain
Seeking some advice for my neighbor who has a problem with the wiring in his 88 or 89 Classic ...
Here are the symptoms :
Replaced a dead alt with a brand new one, the truck runs great and can be driven all day. However when darkness falls, and the trucks lights are put on, the battery drains and quickly dies.
Any advice as to where to begin looking for such a wiring short?
Anyone had a similar problem before?
Do we have to make an offering to the Lucas gods?
Thanks for any insight !
gregory.pearson is offline   Reply With Quote
Old 12-04-2007, 09:19 AM   #2 (permalink)
fuddmucker
pie4foou's Avatar
Gallery: 2
humm.... does it drain when the car is off and just sitting?
pie4foou is offline   Reply With Quote
Old 12-04-2007, 02:12 PM   #3 (permalink)
Unhook the alternator at night, if the battery isn't dead in the morning, you got a bad new alternator.
Old 12-04-2007, 02:14 PM   #4 (permalink)
1990 RRC
Nope, strangely its only draining when the lights are flipped on. It runs and sits fine as long as they're off.
I lent him my trusty 'ol owner's manual with the wiring diagram, but I don't think he's gotten very far. It's dissapointing because this is/was the better of his two Classics.
Old 12-04-2007, 05:35 PM   #5 (permalink)
test alternator output under load, that shall tell you, is the alt connected properly? how is the battery, does it have a full charge, does it hold charge?
carlosz is offline   Reply With Quote
Old 12-04-2007, 05:35 PM   #6 (permalink)
OkieRover's Avatar
Gallery: 2
My alternator was the cause as well. If you got real close you could actually hear a high pitch sound coming from it.
I punch my clown daily.
Old 12-07-2007, 08:24 AM   #7 (permalink)
fuddmucker
pie4foou's Avatar
Gallery: 2
I had a drain on my battery and it would die pretty much over night and i couldnt find out what it was.... i took it to my uncle's shop and he said that theres a drain on one of the interior lights even though non of them are lit up... put a negative disconnect and its worked fine for me, sounds like a diffrent problem then what you have sry
Battery drain & upper radiator hose russdonna Discovery Series I 0 08-15-2007 12:39 PM
Battery Drain Kevin88RRC Range Rover Classic 6 07-01-2007 02:55 AM
Door not unlocking with key problem bruinfan90241 Range Rover P38, Mk III and Range Rover Sport 3 03-15-2007 02:12 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
Power failure-2000 RR-please help fdbandit Range Rover P38, Mk III and Range Rover Sport 10 09-28-2005 01:07 PM
