When I started her up this morning and let her idle, I heard a squealing sound coming from under the hood. I stepped on the gas pedal and the sound went away. On my ride home I noticed the interior tach lights and radio lights dim, then go back to normal after a minute or two. I have a feeling it may be the alternator on it's way out.....
Has anyone out there experienced similar symptoms? |
#5 (permalink) | |
#7 (permalink) | |
The belt does not leave the top of the alternator and head straight for the PS pump. It goes around the water pump. Didn't you ever wonder why it rubs on the fan shroud? |
#8 (permalink) | |
Went in to take a look and can't find anywhere to tighten the belt. It continues to squeal until I step on the gas. I can live with it as long as it's not my alternator. If it is my alternator, I bought an extended warranty through Warranties 4 Wheels ( I see they are now advertising on the forum) My alternator is covered if it should go bad so I'm not overly concerned, just don't want to get stranded and have to get towed back. The sound is intriguing and would love to know what the culprit is. |
#9 (permalink) | |
Rocky Mountain High
![]() Join Date: Sep 2005
My guess is the belt needs replaced or the tensioner is getting worn....Are you haveing any other problems with it? |
#11 (permalink) |
Make sure that the belt is routed correctly: http://www.roverparts.com/Tech_serpe..._defender.html
