Old 12-01-2005, 12:44 AM   #1 (permalink)
rovering??
1st rover's Avatar
Default belt tensioner
so after a long trip i hear a loud screachin/whining /knocking from the engine bay..
thaught there was something really wrong... so i pulled over..
did not fing any thing..
the noise changed with changing rpm's
so i finally i got out my scope
and had the motor idle..so it is the tensioner pulley the one below the ac..
and the one below the water pump is also on its way out...
any cheap replacement suggestions?
the cheapest ive found is something like $138 odd
but i also found this...click here[b]the pic is down here..
ok so just wanted to know if any one has tried changing the bearing before?...
-Nikunj
1993 Range Rover Classic LWB
1995 VW JETTA
1st rover is offline   Reply With Quote
Old 12-01-2005, 07:40 AM   #2 (permalink)
Otherwise known as STEVE
They're on sale at DAP for $95 for oem (the spring loaded one). It's usually just easier to replace the assembly than to press out the bearings. Replacing the whole assembly means you get a fresh spring as well...
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 12-01-2005, 01:42 PM   #3 (permalink)
If your Range Rover has v-belts (if it's a '93 it does) I have a perfectly good tensioner out of one of my trucks that I would sell for $20 plus shipping. Contact me directly at paulgrant@mac.com if you are interested.
Old 12-01-2005, 01:43 PM   #4 (permalink)
If, by some odd circumstance, you have a serpentine set up I also have a tensioner out of my Disco that I would sell for the same amount, $20 plus shipping.
Old 12-04-2005, 11:47 PM   #5 (permalink)
Idiot Savant
Motorcars LTD has the shaft bearing for 30 something bucks...yes they are relatively easy to change. You need a good gear puller to get the job done (2 jaw worked the best for me...due to the limited surface space on the pully assymbly).
1967 Rover 2000TC
scuffdog is offline   Reply With Quote
