Old 05-22-2007, 05:17 PM   #1 (permalink)
LANDY96's Avatar
Default Best Drag link? Rovertym?
Well, found out that the drag link is bent! Whats the best action? Is Rovertym going to be my best option? I assume so..... I also assume that i will have to get the relocation kit for the steering stabilizer.... sigh....money in.....money out......
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 05-22-2007, 07:59 PM   #2 (permalink)
Ben
TN-LR3's Avatar
rovertracks makes strong stuff
1997 D-90 #1345- back to stock
2002 Dodge ram 2500CTD- dd/tow rig
looking to do 1 ton toyota or rover
TN-LR3 is offline   Reply With Quote
Old 05-23-2007, 07:18 PM   #3 (permalink)
KevinNY's Avatar
DAP has a kit with the drag link, tie rod and greasable ends for a great price. I have had great luck with them as have others I know.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
Old 05-24-2007, 03:27 AM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
Putting on a heavy duty track rod does not mean that you have to relocate the steering damper. I run a heavy duty maxi-drive track rod, but the steering damper is in its original position.
p76rangie is online now   Reply With Quote
Old 05-24-2007, 11:34 AM   #5 (permalink)
Nomar's Avatar
...and your damper is probably unscratched, right?
I think the Rovertym is well worth the money...
The mere fact that a flame thrower even exists is proof that sometime, somewhere, somebody said to themselves, "You know, I'd like to set those people over there on fire, but I'm just not close enough to get the job done."
Nomar is offline   Reply With Quote
Old 05-24-2007, 02:10 PM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
I have had to put one new one on in 8 years. It is protected by the track rod.
Old 05-24-2007, 02:44 PM   #7 (permalink)
fivespddisco's Avatar
Gallery: 10
I have what you need $248 with a HD ball joint
Check out WWW.Lucky8LLc.com 716-898-8153 Justin
fivespddisco is offline   Reply With Quote
Old 05-24-2007, 02:46 PM   #8 (permalink)
Gallery: 10
Do you drive the truck?
Old 05-24-2007, 10:12 PM   #9 (permalink)
Ian Matthews
p76rangie's Avatar
Don't start that again.
Old 05-25-2007, 07:38 PM   #10 (permalink)
Gallery: 10
just asking MR "my track rod protects it"
Old 05-25-2007, 07:53 PM   #11 (permalink)
Did anyone mention that the Rovertym one is pretty good?
1987 Range Rover
1989 Range Rover
1995 Range Rover County LWB
1998 Range Rover 4.6HSE
TNRRClassic is offline   Reply With Quote
Old 05-25-2007, 08:47 PM   #12 (permalink)
Nomar's Avatar
It's very good. I've had one for almost 4 years.
And I wheel the truck.
Old 05-25-2007, 11:13 PM   #13 (permalink)
Ian Matthews
p76rangie's Avatar
I have just realised the question was about drag links rather than track rods.
Would not recommend upgrading the drag link to a heavy duty option, they can break the steering box. You can still drive with a bent drag link, not so with a broken steering box.
The drag links and track rods on a Rangie are designed to be a bit flexible. You can get away with (and it is a good idea) upgradingyour track rod. The extra stiffness just tends to shorten the live of the ball joints.
But putting in a stiff drag link can transmit any shock from an impact to the wheel to the steering box. Breaking the box. Without a steering box, the car is staying where it is.
Old 05-26-2007, 11:10 AM   #14 (permalink)
I was joking. I have the RTE model, too, and I have had excellent results.
Amazingly enough, my steering box is intact.
1987 Range Rover
1989 Range Rover
Old 05-26-2007, 06:03 PM   #15 (permalink)
Ian Matthews
p76rangie's Avatar
But why did you upgrade it?
The money you paid would have paid for a decent bash plate that would have protected it and anything else across the front.
How many CVs have you broken?
How many axles?
How many Crown wheel and pinions.
How many diff centres.
How many mounts have you ripped off the chassis.
How many shocks have you snapped the ends off.
How many engine mounts have to ripped apart.
How many A frame brackets have you ripped from the diff housing.
If YOU have not broken one, it must not happen. Is that what you are saying.
