Best lift combo? - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
post #16 of 30 (permalink) Old 12-30-2012, 05:29 PM
roverandom's Avatar
Quoted: 3 Post(s)
I run 285/75R16's with a OME 2" lift, a set of 30mm wheel spacers and some liberal wheel arch trimming. I flex close to stock with the winch/ARB Bumper and loads of off road gear which is great. I stand close to stock height.
One thing that has not been brought up in the other posts is you are going to have serious power issues towing a heavy trailer with the Rangie all loaded up on 33" tyres. You could go for a lower gear set in the differentials or fit a Defender LT230 T'case with a lower 1.410 or 1.667 high range ratio (low ratio is the same). However, with those lower gears you increase the risk of braking the diff/axleshafts/CV's. Something to consider.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline
post #17 of 30 (permalink) Old 12-30-2012, 06:54 PM Thread Starter
enterusernamehere's Avatar
Quoted: 0 Post(s)
I'm planning on swapping my diffs for 4.11's with a locker in the rear, and I'm probably going to be throwing in a better cam. Also I plan to swap in a R380, so I'll have a little more control.
enterusernamehere is offline
post #18 of 30 (permalink) Old 12-31-2012, 07:46 AM
roverandom's Avatar
Quoted: 3 Post(s)
Then also think about swapping out the axle shafts and CV's for a stronger set (Ashcroft/GBR) and upgrade the front, open two pin differential carrier for a four pin at the same time. Those lower gears and increased vehicle and trailer weight will find the weak links fast off road.
I have found I have more control with an automatic than with a standard gearbox, especially off road. But that tends to be more about personal preference than anything else.
Matt.
post #19 of 30 (permalink) Old 01-01-2013, 05:16 PM Thread Starter
Quoted: 0 Post(s)
I personally can't stand the auto. Doing some towing, or just driving along, come to a hill and the dam thing down kicks and I'm red lining it! Got a pretty torquey V8, may as well use it. But yeah, that is probably a good idea to put some hd stuff in. Do it right the first time, so I don't have to keep replacing the scrap metal.
post #20 of 30 (permalink) Old 01-01-2013, 07:54 PM
Ian Matthews
p76rangie's Avatar
Quoted: 151 Post(s)
You can adjust the kickdown to come in earlier or later. You just adjust the tension on the cable next to your throttle cable.
p76rangie is offline
post #21 of 30 (permalink) Old 01-01-2013, 08:42 PM Thread Starter
Quoted: 0 Post(s)
True, but I just like to be full control. Select a gear, push the throttle, and ride the torque curve. But that's just my preference.
post #22 of 30 (permalink) Old 01-02-2013, 07:38 AM
90 red rover's Avatar
Quoted: 0 Post(s)
I had bought my 1990 with a 2" OME medium duty lift and found that the rear springs were sagging quite a bit. I liked how soft they were and would love it if they came just a bit longer but I replaced them with some 2781's I believe. They are between the mediums and the HD's, that restored the rear ride height - I should note that my BOGE units is not working. I agree with p76 and roverrandom that you want the softest springs and so maybe the air bags and the mediums are a really good mix, especially if you could control them independently from the cab to help with some off camber situations!
Brian
1990 RRC
1996 Toyota Avalon - hers
1989 F-250
1994 Toyota Pickup
90 red rover is offline
post #23 of 30 (permalink) Old 01-02-2013, 07:41 AM
Quoted: 0 Post(s)
what years came with the 4 pin carrier and 24 spline axle shafts? also what years disco axles would be a direct swap into a classic?
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
post #24 of 30 (permalink) Old 01-06-2013, 11:34 AM
JeffG's Avatar
Quoted: 0 Post(s)
I think my springs are well past their expiration, I'd like more aggressive tires, but I don't want a rough ride. I've always wondered if anyone has taken either of these approaches for a mild lift, which is from rangerovers.net:
"Lifts using Standard Land Rover Springs: For those wanting to experiment with different springs on their Range Rovers, it is good to know that all Land Rover coil springs are interchangeable in terms of fit. There is a listing of Land Rover springs, part numbers, spring rates and lengths done by the Land Rover Club of Luxemburg. One common approach for a soft 2 inch lift is to replace the standard 133 lb/in front springs with your rear springs (150 lb/in NRC4305 or 120-180 lb/in NTC3285). Then you can use rear Discovery springs (NRC 8044, 210 lb/in) on the back end to even it up. . . . I wanted to try the relatively long NRC4304 springs on the rear but sold my Classic before I had a chance. Andy Grafton lifted his suspension by using longer springs without changing shocks -- he found articulation appeared to remain the same but the vehicle is riding 2" higher on the shocks."
The link to the LR spring listing is: PART
Also, this guy apparently had success with the LR police springs but I haven't been able to find a US distributor:
NRC4304 Police Spec Springs
Finally, there is more info here, including an apparent quote from Mr. Matthews about using LR springs for a 2 inch lift:
Range Rover Classic Tire Choices
1992 RRC County. 229k.
2003 Discovery S, 113k miles, 285/75 KM-2s, OME HD, Rocky Mtn Winch Bumper, HF Winch w/ blown solenoid, working through the major service list
JeffG is offline
post #25 of 30 (permalink) Old 01-07-2013, 09:14 PM
roverandom's Avatar
Quoted: 3 Post(s)
Using LR springs is how it was done back in the day before everyone and his dog started making spring "lift" kits for Land Rovers. It works very well and while it was cheap and easy to do when I lived in the UK I have found it more expensive and way more difficult to source new OEM springs in non standard spec in North America.
For a mix and match approach it really helps to know the loaded/unloaded and front/rear axle weights. Good shocks also makes a noticeable difference.
"what years came with the 4 pin carrier and 24 spline axle shafts? also what years disco axles would be a direct swap into a classic?"
Some V8 Defender rears came with a 24 spline four pin or with some machining work a 4.6 P38 RR four pin can be made to work, but frankly for all the bother, you may as well fit an ARB/Ashcroft/Detroit and get a super strong four pin differential and a real locker to boot.
Matt.
post #26 of 30 (permalink) Old 01-08-2013, 05:23 PM
grnthng's Avatar
Quoted: 1 Post(s)
When I did my conversion (air to coils) on my '93 I used OME 751's (mediums in front) and Hd in the rear....very stiff and would not recomend the HD's
Ultimately your best bet is to go mediums.....wether you use OME or Terrfirmas, good for 2'' and you could always go with a 1'' spacer later on!
Depending on how much you are going to articulate your suspension, you will need to get longer shocks and extended brake lines as well!
This will avoid the need for new radius arms...you could always just use the castor correcting bushings in your stock arms if you dopn't like your steering feel! I diidn't feel any differnce with my lift!
Havn't heard of any driveshaft change...unless you go to 5'' or a LT230 transfercase swap!
Your good till 33'' for tires, but that's it before you get into cutting fenders and body lifts!
Look up Lucky8ll out of Buffalo....they have anything you need!
grnthng is offline
post #27 of 30 (permalink) Old 01-08-2013, 06:24 PM
The type to cop a Range along with all the features
greenmountainski's Avatar
Quoted: 5 Post(s)
I love the idea of those airbags.
For my project RR I am going to be fitting a direct propane, gasoline tank replacement and a spare wheel propane replacement along with an aux gas for starting the truck, with all that weight in the back those air bags look like a cheap, easy and durable idea. And those bags can also make use of the air tank from the old air suspension. Cool link.
Now I'm in the RANGE, switchin' lanes doin a buck'n CHANGE
greenmountainski is offline
post #28 of 30 (permalink) Old 01-09-2013, 01:36 PM
Quoted: 0 Post(s)
" frankly for all the bother, you may as well fit an ARB/Ashcroft/Detroit and get a super strong four pin differential and a real locker to boot."
i like that. is it safe to assume that with my 10 spline axles i could get a 24 spline arb, buy some 24 spline aftermarket shafts and that would all go in my housings? who makes good axle shafts? anyone running a fancy alloy like 300 m?
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
post #29 of 30 (permalink) Old 01-18-2013, 04:31 AM
John C's Avatar
Quoted: 0 Post(s)
285/75 BFG ATs with 2.5" springs (our own brand), Koni Heavy Track Shocks +2 and Firestone airbags inside rear springs (airbags were not inflated when this pic was taken).
John C
1999 DI - LR HD Springs
1996 DI - parting out
1995 DI - parting out Scorpion Racing Extreme Kit
1994 RRC LWB - 3" AG lift
1990 Kawasaki KL650B Tengai - parting out
1989 Kawasaki KLR650
1988 Kawasaki KLR650 - parting out
1979 Puch XK
1980 Puch Magnum MKII
1980 Puch Magnum MKII - parting out
John C is offline
post #30 of 30 (permalink) Old 01-18-2013, 06:51 AM
Quoted: 0 Post(s)
any of you guys running a 2" terra firma?
agthird is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
P1171/1174 combo nasa25 Discovery Series II 14 02-04-2012 02:25 PM
alarm/horn combo tracieloeterratours Discovery Series II 1 11-06-2011 04:07 AM
New FOB or BeCM combo? PUFF1N Range Rover P38, Mk III and Range Rover Sport 2 10-23-2011 07:25 AM
wheel and tire combo lambo Discovery Series I 1 09-12-2010 09:58 PM
You may post new threads
You may post replies
