Where is my Black Son?
So I am going to take a look at my spark plugs tomorrow(don't know when they were last done) and see if they need to be replaced.
Anything particular I should get? How are the fancy shmancy Bosch Platinum +4's for this vehicle? Should stick to just normal ones? Any advice would be great.
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler. 1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
Super Moderator
I've never tried platinums, or iridiums either, but I do use exclusively ordinary NGK's and that's on a supercharged engine. Great sparkplugs!
Don't use platinums on that, waste of money and I've heard a lot of reports of folks having them cause problems on engines not designed specifically for them.
I use whatever is cheapest in all my Rovers and change them as needed. Right now I'm running Autolites that I got for 99 cents each. You can't go wrong using what the owners manual lists.
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
Ok thanks.
It is raining out here today (and its cold) so I won't be talking a look see under the hood. Gives me sometime to check out opitons in the local CT. Thanks.
Champion 322s . Don't waste your money on anything else, it'll likely screw it up!
The mere fact that a flame thrower even exists is proof that sometime, somewhere, somebody said to themselves, "You know, I'd like to set those people over there on fire, but I'm just not close enough to get the job done." |
#9 (permalink) |
Ian Matthews
Never had much luck with Champion. Every now and then some salesman convinces me that they have changed and I put them in. Each time within a short period I have to pull them back out and replace them with NGKs or similar quality brand.
#10 (permalink) |
Super Moderator
I agree. I originally alternated Champion which came with the vehicle when I purchased it new, with NGK's, then I went back to Champion and found that they didn't give me the performance that the NGK's offered. I now only fit NGK's.
