Biggest Tire Size on Stock Rim - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 18 (permalink) Old 07-26-2011, 11:39 AM Thread Starter
troverman's Avatar
Quoted: 0 Post(s)
I have a 1992 Range Rover currently running 225x75x16 General Grabber AT2 tires on the TWR 5-spoke stock rim. My Rover has a 2" spring lift. What is the biggest tire that will mount on these rims and also not have a rubbing problem? Can I put 285x75x16 (32") tires on? I need more clearance off-road but I like the stock rims.
troverman is offline
post #2 of 18 (permalink) Old 07-26-2011, 07:27 PM
roverandom's Avatar
Quoted: 3 Post(s)
Stock rims are 16"X7" wide. A 285/75r16 tyre is over 33" tall and 11.5" wide. Most (all) tyre manufactures recommend a minimum 8" wide rim for that size. You can just squeeze it on the stock rim but be aware that you run the risk of 'pinching' the tyre on the rim. This could cause a doughnut like effect and cause improper tread contact and tyre wear if you drive on the road alot, off road, it doesn't matter. One of the nice things about stock Range Rover wheels is they have a nice wide safety bead edge so it will be hard (but not impossible) to drive the tyre off the bead.
With a little trimming the tyres will fit with a 2" lift but the width will cause issues with the steering and articulation. You could use wheel spacers but then you will need to get serious with the sawsall.
Lot's of folks have run 285/75r16 on classics. Another option is a 255/85r16 tyre, also a 33" tall tyre but only 10.5" wide so it will fit the wheel correctly and cause less issues with the lift. Both sizes have their place.
Hope this helps.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline
post #3 of 18 (permalink) Old 07-27-2011, 03:30 AM Thread Starter
troverman's Avatar
Quoted: 0 Post(s)
Roverandom,
Thanks for good info. Will the 255 tire cause rubbing issues during steering and / or during maximum articulation?
I would be fine with a 255x85 tire size. Just looking for a little more clearance under my axles and differentials. I think the tires I have on now are about 29 or 29.5" tall. And in reality they allow me to go most places the big-tired trucks go, if I'm careful with my line.
post #4 of 18 (permalink) Old 07-27-2011, 08:37 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 37 Post(s)
With a 3" lift under full articulation I had minor body contact at the rear fender well door lip area running 255/85/16.
I would recommend sticking with a 32" but you may still have a bit of rubbing. Either with 235/85 or 265/75 for a wider tire.
1972 MGB
2007 Chawton White LR3
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community and Forum
716-898-8153
Have a DII you need a drive shaft click here
Want a
best read this first
Need used parts?
ArmyRover is offline
post #5 of 18 (permalink) Old 07-27-2011, 11:03 AM Thread Starter
troverman's Avatar
Quoted: 0 Post(s)
Army, was there any rubbing during normal steering? I still have swaybars connected and rear does not have extended length shocks, so that probably limits rear articulation.
post #6 of 18 (permalink) Old 07-27-2011, 12:49 PM
ArmyRover's Avatar
Quoted: 37 Post(s)
there was rubbing at full lock. I adjusted the steering stops and it wasn't to bad then. With a 2" lift though I would think your going to see rubbing regardless with 33" tires, unless you cut the openings.
1972 MGB
716-898-8153
Want a
Need used parts?
post #7 of 18 (permalink) Old 07-28-2011, 03:34 AM Thread Starter
troverman's Avatar
Quoted: 0 Post(s)
Maybe what I'll do is add a 2" body lift to gain clearance for the tires. How difficult s it to add a body lift? Do you just add the spacers to the body mounts one at a time? Anything get messed up like shift / steering / transfer linkages?
post #8 of 18 (permalink) Old 07-28-2011, 05:19 AM
ArmyRover's Avatar
Quoted: 37 Post(s)
Unbolt the body and raise it up and slide in the new spacer pucks. Steering shaft is always good to extend but some get away without doing it. Shift linkages work out fine if memory serves. Seat belt mounts in the rear need extended.
I have the kit with the extended steering shaft already done but I've never got around to installing it. Didn't really need it with the RTE 3" springs
1972 MGB
716-898-8153
Want a
Need used parts?
post #9 of 18 (permalink) Old 07-28-2011, 07:12 AM Thread Starter
troverman's Avatar
Quoted: 0 Post(s)
how many body mounts are there? Do they unbolt from underneath or from inside under the carpet, or both?
Do you have a kit you wanted to sell?
post #10 of 18 (permalink) Old 07-28-2011, 07:57 AM
ArmyRover's Avatar
Quoted: 37 Post(s)
Do a search on it to be sure but if I remember correctly it's 8. The kit i have is missing the extenders for the rear seat belts. I'm sure if you wanted it we could work out a deal since I doubt I'm going to use it.
1972 MGB
716-898-8153
Want a
Need used parts?
post #11 of 18 (permalink) Old 07-28-2011, 08:12 AM Thread Starter
troverman's Avatar
Quoted: 0 Post(s)
I guess I'm wondering why the seat belts need extensions? Aren't they bolted to the rearmost pillars, the rear wheel well, and the female receivers bolted to the floor pan?
Regardless, when I swapped interiors in my Classic the rear seatbelts fully retracted and so I don't even have them installed (except center lap belt).
How much would you want for your kit?
post #12 of 18 (permalink) Old 07-28-2011, 08:21 AM
ArmyRover's Avatar
Quoted: 37 Post(s)
Say $135 plus shipping?
1972 MGB
716-898-8153
Want a
Need used parts?
post #13 of 18 (permalink) Old 07-28-2011, 08:26 AM Thread Starter
troverman's Avatar
Quoted: 0 Post(s)
Did a bit of research...is the radiator mount affected at all? Is there any welding or anything like that involved? And did you say how tall the lift was? 2"?
$135 doesn't seem too bad, I just need to decide if I actually want to do it and make sure it will work for me.
Thanks
post #14 of 18 (permalink) Old 07-28-2011, 08:36 AM
ArmyRover's Avatar
Quoted: 37 Post(s)
It does have the radiator spacers. The welding has already been done on the kit I have. That is for extending the steering shaft.
1972 MGB
716-898-8153
Want a
Need used parts?
post #15 of 18 (permalink) Old 08-25-2011, 03:10 AM Thread Starter
troverman's Avatar
Quoted: 0 Post(s)
Body lift is now installed (Not a fun ordeal). I really want 33" tires, maybe go with the 255x85x16 size. I'm not adverse to some minor fender trimming if necessary.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
stock tire size defenderfan Wheels and Tires 6 05-07-2011 09:13 PM
Switching rim & tire size. flyboyaviator Wheels and Tires 4 03-25-2010 05:13 PM
biggest size tyre without rubbing? Amclutch Range Rover Classic 6 03-12-2010 09:23 PM
what is the biggest tire size on a stock 03 disco 2003discoII Discovery Series II 8 08-08-2009 08:19 PM
Max Size tire on my Stock Disco II drewdown Wheels and Tires 12 04-05-2009 09:43 AM
You may post new threads
You may post replies
