Biggest Tire Size on Stock Rim - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
post #16 of 18 (permalink) Old 08-25-2011, 04:41 PM
Ian Matthews
p76rangie's Avatar
Quoted: 72 Post(s)
Originally Posted by troverman View Post
Body lift is now installed (Not a fun ordeal). I really want 33" tires, maybe go with the 255x85x16 size. I'm not adverse to some minor fender trimming if necessary.
A spring lift really does not allow bigger tyres, only a body lift does. So you will find the extra work is well worth it in the long run.
You will find that 255's on standard rims will largely give you issues on the cabin side of the wheel arches. Keep an eye out near the shock towers on full articulation on the front.
To keep full articulation (that is axles still touching bump stops from time to time) I was still going to trim the front fenders a little near the bottom to fit the 255's on standard rims. On the rear I had to drop the bump stops an inch to stop them going up so far.
But then I started my ute and stopped attempting to modify the 4 door and stuck with the 235/85/16 tyres I had. Which by the way only just clear with a 2 inch body and a 2 inch spring lift.
p76rangie is offline
post #17 of 18 (permalink) Old 08-27-2011, 09:04 AM
cdb
Quoted: 0 Post(s)
If you are going to run rocky trails don't use aftermarket 8" wheels. They will de-bead. With the tires you are talking about the 7" stock alloys are the best (yes - the 285/75/16) because their bead is excellent and most aftermarket stuff is crap by comparison. Also the wider tire really forces itself against the bead.
I've run stock rims (alloys and D110 steelies) for 20 years, on all kind of nasty trails, and the only de-beading I ever had was when I went to Pro-Comp 8" 8068 rims running 35" Nitto Mud Grapplers on my heavily modified 1991 RRC Hunter. Not a very tough trail, 12 lbs of pressure. Twice in 10 minutes. Irritating. When the same tires were on the stock alloys
This debate has come up many times on the D90 Forum and generally follows the same pattern as this thread.
cdb is offline
post #18 of 18 (permalink) Old 08-27-2011, 09:11 AM
cdb
Quoted: 0 Post(s)
Oh yes, one more thing: I have a body lift on my 1995 RRC and hate the damn thing. Linkage is tougher to shift, console fit is poor, and much more swaying.
It came that way.
I will probably go to 3" springs after I have the lift kit removed because I'm running 255/85/16 BFG KM2.
I have all the necessary cranked radius and trailing arms and double cardon propshafts to lift it that extra inch so the cost is just in removing the lift kit.
Then someone can have it.
cdb is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
stock tire size defenderfan Wheels and Tires 6 05-07-2011 10:13 PM
Switching rim & tire size. flyboyaviator Wheels and Tires 4 03-25-2010 06:13 PM
biggest size tyre without rubbing? Amclutch Range Rover Classic 6 03-12-2010 10:23 PM
what is the biggest tire size on a stock 03 disco 2003discoII Discovery Series II 8 08-08-2009 09:19 PM
Max Size tire on my Stock Disco II drewdown Wheels and Tires 12 04-05-2009 10:43 AM
You may post new threads
You may post replies
