Old 02-04-2006, 02:44 PM   #1 (permalink)
Default Blower motor help
HI All,
The blower motor on my 1988 RRC runs REAL slow- motor seems to follow the switch- low, med, hi- (by sound) but no/very little airflow- I have most of the dash apart- and my blower motor is on the opposite side (Passenger)of the heater unit from all the pictures
The guy I got the RRC from said something like "... I put the blower on slow speed, al you will need to do is switch it back to high...." and naturally he is nowhere to be found.
I've seached the forum, and it looks like it might be the resistor or the blower motor itself. ne of the searches saif it was behing the right vent? is that the OUTSIDE vents? or the dash vents?
Is there a check for the resistor (and where is the little gem) or do I just buy another one and hope it works.
Ohmed out switch, checks good.
The a/c side of the system works fine- separate blowers- they work and blow good.
Any thoughts? as it is starting to snow here outside Dayton OH.
Thanks,
Carl
Kleantouch is offline   Reply With Quote
Old 02-12-2006, 06:18 AM   #2 (permalink)
Just to finish this thread- changed the blower motor, now it works great.
Now we can play in the snow with heat!
Old 02-12-2006, 08:19 AM   #3 (permalink)
94 Defender 90
cellulararrest's Avatar
Doesn't it feel great when you get heat back? haha.
S.N.H.L.R.
cellulararrest is offline   Reply With Quote
Old 02-12-2006, 05:20 PM   #4 (permalink)
Otherwise known as STEVE
SUCH a common problem on RRC's...
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
