Old 11-20-2005, 06:34 PM   #1 (permalink)
Rocky Mountain High
Funrover's Avatar
Default Blown Transmission line
I went to go ski today and my trans. line that plugs into the left side of the radiator blew apart at the bend where it turns to rubber....Any suggestions on where to get parts? Alantic british has it for $140.00 was hopeing for less...Thanks
Old 11-20-2005, 06:37 PM   #2 (permalink)
01001010's Avatar
Gallery: 15
Try RoversNorth, they normally have stuff a few dollars under AB, and it doesnt get any lower than that
JC...
Old 11-20-2005, 06:38 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
I looked and was not able to find the part!!
Old 11-20-2005, 07:05 PM   #4 (permalink)
Heres an idea. Not sure if it will work.
but cut part of the steel line and run a rubber hose with clamps. Most trannies dont have very high line pressures. Maybe sixty tops.
It might work for a bit until you can find the line you need. And I wouldnt go used only new.
Old 11-20-2005, 07:07 PM   #5 (permalink)
Rocky Mountain High
Funrover's Avatar
That is what I am gonna do for temporary!!!!!! the good news is after today the underside of my truck will never rust......Bad news is I can barely see out the windows......
Old 11-20-2005, 07:34 PM   #6 (permalink)
94 Defender 90
cellulararrest's Avatar
Give them a call. They have a lot of things that aren't on the website. Extremely helpful guys over there.
S.N.H.L.R.
cellulararrest is offline   Reply With Quote
Old 11-20-2005, 08:11 PM   #7 (permalink)
DISCO INCUBUS's Avatar
Default Trans cooler line
Try this place WWW.northeastbritishparts.com.
Cooler line $89.95
DISCO INCUBUS is offline   Reply With Quote
Old 11-20-2005, 08:56 PM   #8 (permalink)
Rocky Mountain High
Funrover's Avatar
If that is the corrent one that is the best price yet...Thanks
Old 11-22-2005, 02:26 PM   #9 (permalink)
Take the line to a hydraulic hose shop, listed in yellow pages or local search. They can replace the flexible portion & crimp with the correct fittings. Same thing goes for Air conditioning lines.
Should do all lines, if one blew, the others probably aren't far behind.
CJH
CJH
1990 Rangie
Philadelphia, PA
choffa@comcast.net is offline   Reply With Quote
Old 11-22-2005, 02:45 PM   #10 (permalink)
Wheeler
SCSL's Avatar
Try Rovers Unlimited here in Denver. They have a ton of RRC & DI stuff lying around. 720/934-7894
Old 11-22-2005, 03:41 PM   #11 (permalink)
Rocky Mountain High
Funrover's Avatar
Went to whistler bearing....They have made a lot of hoses for me before....total price $37.71...... time to go put it in!!
Old 11-22-2005, 07:47 PM   #12 (permalink)
Rocky Mountain High
Funrover's Avatar
Well the rover is back up and running!!!!!! That trans filter is a pain in the butt!!!!.... Thanks for the info everyone!
