Links
Old 04-26-2008, 11:00 AM   #1 (permalink)
GreatDivide1's Avatar
Arrow on board air thouht??
hey all im thinking about converting my ac to on board air...any thoughts or pics of your set ups would be greatly helpfull...havent done this before soo just trying to check out others setup to get ideas for mine...thanks
91 G.D.E. project/daily winter driver
93 BMW 325i project/daily summer driver:SOLD:
00 BUELL cyclone custom
http://www.snhlr.org/
GreatDivide1 is offline   Reply With Quote
Old 04-26-2008, 02:04 PM   #2 (permalink)
Thor's Avatar
I've heard the output of air is slow... but my memory could be off.
I use a 15 lb. Power Tank and an electric pump (100% duty cycle) under the hood.
Todd
Carpe Rangius Roverum
Old 04-26-2008, 02:55 PM   #3 (permalink)
Rebuilding Rover
ArmyRover's Avatar
Belt driven York for OBA - DiscoWeb Message Boards
On-board air - DiscoWeb Message Boards
A/C compressor as pump? - DiscoWeb Message Boards
There are few links to get you started.
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 04-27-2008, 12:20 AM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
What sought of air-on compressor do you current have?
I converted mine a few years back, but I had a York 10CFM compressor already fitted as my air-con compressor.
Basically you need a few things:
1) Tank
2) Pressure relief valve
3) Pressure switch.
4) Hose to run from compressor to tank.
The first thing to decide is where you are going to fit the tank and what size will fit.
Next go searching Ebay of cheap hardware stores and find a home compressor with a tank the size you need. I have about 22 litres and the complete home compressor cost me about $75. This is the cheapest way to get all the gear you need.
Once you get the compressor, remove and throw away the 110v motor and compressor. The pipe that went from the compressor to the tank is the pipe that you will use to fit the air line from your compressor to.
Buy some hi-temp hose to run from the compressor to the tank. You need hi-temp stuff as the compressor (and the air from it) gets very ot. Standard air line type hose just melts and blows apart.
On the electrical switch on the tank, run one side of the switch to earth and the other side to the earth connection to the relay controlling the air-con compressor. This will switch the compressor off when the tank gets to pressure and back on when the pressure drops. The power activation side of the relay goes to a switch inside the cab so that you can decide when it runs.
The air going into the compressor needs a filter on the hose, just use the filter that came with the home compressor you purchased.
p76rangie is online now   Reply With Quote
Old 04-27-2008, 05:07 PM   #5 (permalink)
p76 thanks great tip on the cheap electric compressor.... good way to get all that is needed in one step....
Engine ticking solved thanks to the Board pdolan Range Rover Classic 2 04-24-2008 05:07 PM
Pressure Issues/On Board Air Options stolenheron Wheels and Tires 17 02-29-2008 07:09 AM
On board air Rover Nick Accessories 11 04-19-2006 10:05 PM
running board installation on 95 LWB AdrianL Range Rover Classic 4 08-20-2005 08:42 PM
Board Monitor YIE100050LNF jonnydanger0 Land Rover Parts and Accessories 0 10-23-2004 12:34 PM
