well just got done with my toddco body lift
![]() went in super easy and i only did a couple things diffrent then the distruction... one i put almost all the bolts in from the bottom up where they want some up and some down..two i didnt remover the bumpers like they want u to....other then that went in great super easy and no change to the way it drives at all.. i would reccomend it to anybody who wants lift without big money.....
91 G.D.E. project/daily winter driver 93 BMW 325i project/daily summer driver:SOLD: ![]() 00 BUELL cyclone custom ![]() http://www.snhlr.org/
Rebuilding Rover
how many inches did you do and what did the body lift run you I've been considering that next along with the extended brake hoses
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
i did the 2in lift as thats all they offer...umm i think 230ish shipped ... sorry it was a rovertym lift will work on pics
Rebuilding Rover
hmmm guess I'll go for the brake lines than I'll get the body lift after we get our tax rebate checks
Ian Matthews
Relatively easy to maek your own lift kit. Just buy 2 inch round solid aluminium bar and cut it into sections the length you want the lift. Drill a hole up the centre and get the required longer bolts. The only fiddly bit is making some bracket extensions for the seat belt tie-downs. You don't need extended brake lines, only have to move the mounting brackets.
hell even better I went to a local off road shop where i was able to obtain 10 3 inch blocks like those used on american body lift kits, then i went to my local steel suplier
(potomac steel in springfield va) and purchased 10 6inch long x 3/8 grade 8.5 fine thread bolts with locking nuts and a couple pounds of flat washers all for less than 50 bucks. i have some more custom work to do before install but once compleeted and said and done I may have spent 100.00 at most. |
#8 (permalink) | |
Rebuilding Rover
oh but I do I have a 3'' old man emu lift ![]()
#10 (permalink) |
ideal, i plan on doing a 3 inch body 5 to 6 inch suspension, 33's, 411 gears. custom front and rear homemade bumpers, side sliders, arb front and rear lockers, lowered radious arms and redrilled swivel balls.
most of it will be done by me some other stuff i will buy or have custom made. hope to have all compleeted by this september. |
#11 (permalink) |
Rebuilding Rover
I'm aiming for the 2 or 3 inch body lift on top of the 3 inch suspension lift so brake lines wouldn't be a bad idea before to long plus mine are 17 years old and probably should be replaced sooner or later regardless
#12 (permalink) |
fuddmucker
I went with rovertym lift as well. The 2" body, and they recommended longer break lines with the suspension that i'm running. I'd have to say I'm quite pleased with the results. I've had the lift for about 5 months or so. Going to pay my friend at the tire wholesaler a visit this summer... hopefully i'll be sitting on 35's for around $50 a tire... but its nothing set in stone. anyone have a problem fitting 35's with just a 2" body lift and 1" suspension? i think at worst i'll have to shave off one side of the wheel wells
#13 (permalink) | |
Ian Matthews
#15 (permalink) | |
Ian Matthews
Went I fitted them I went from a 1 inch body lift to a 2 inch lift and bigger tyres. The car was more stable afterwards than what it was before the changes. I run 255/85/16 BFG MTs on those rims and they are my road tyres. I also have a set of 15 inch rims which are an extra inch wider. The extra width on on the inside and the outside distance is the same as the Disco rims. On these I run my off-road Simex tyres. |
| Thread Tools | |
| Display Modes | |
| RTE Body Lift Problems | emmodg | Range Rover Classic | 2 | 06-01-2006 06:35 PM |
| body or suspension lift? | natvboy | Discovery Series I | 17 | 05-09-2006 07:23 AM |
| Body Lift Question | LAYDOUT777 | Discovery Series I | 20 | 03-14-2006 02:10 PM |
| body lift first? | drewclare25 | Discovery Series I | 0 | 02-21-2005 11:10 AM |
| body lift on disco | scruff6979 | Discovery Series I | 1 | 01-09-2005 06:46 PM |
