Old 05-08-2007, 11:14 PM   #1 (permalink)
Default Boge Unit Removal
Does anyone know the size spanner required to remove the lower portion of the Boge unit. Shop manual says thin wrench but does not say which size and would love to know before getting under there. Thanks Guys.
Triple R is offline   Reply With Quote
Old 05-17-2007, 11:14 AM   #2 (permalink)
DougG's Avatar
Are you taking it off to put a new one on, or are you just removing it completely? If the latter, I used a 4.5 inch angle grinder to cut the thing out Not sure what size spanners to use though
Doug
61 Series II 109 SW
88 Range Rover Classic SWB
96 Range Rover P38
DougG is offline   Reply With Quote
Old 05-19-2007, 06:29 AM   #3 (permalink)
Had it taken off already,I have to replace the ball joint on the A-arm (clunking).Thought it was the ball joints on the Boge unit. I have the heavy duty springs so I really dont need the self leveler. Curious to see how it rides without the Boge. Figured while i am replacing the ball joint I will do the bushings on the A-arm too. Did not want to cut it just in case I want to re-install it.Time will tell. Thanks for the reply,appreciate it.
