Old 12-05-2006, 12:22 PM   #1 (permalink)
RageRover's Avatar
Lightbulb Borg Warner T-Case Refill...
Hey Oscar, hopefully you found this thread, here is a pic of what you need to do to renew the ATF in your BW T-Case.
Remove the Fill hole first, and then remove the drain plug last, and let all the old ATF drain out. Then put the drain plug back in and start filling the T-Case with new ATF til' the level in the T-Case reaches the Fill plug level, reinstall the fill plug and then you are good to go. Hope that helps!
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
