Old 01-20-2008, 10:29 PM   #1 (permalink)
repete's Avatar
Default brake fluid on my carpet!
So there I was changing a door light timer under my dash when I found a active LEAK at my master cyl. at the plunger. I am posting this to see if anyone has seen this and has been able to successfully repair it. the truck is a 93 LWB w/abs any advice would be great!
repete is offline   Reply With Quote
Old 02-01-2008, 10:25 AM   #2 (permalink)
repete's Avatar
So by the huge amout of replies i've gotten on this thread, i suppose this hasn't happened to many of you. If there is any of you that has removed your abs master cyl/valve block, or even taken one apart, PLEASE reply and let me know about it THANKS!
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
[D2] Service Intervals rmuller Tech & DIY 1 05-10-2007 09:11 PM
Brake Fluid swap wimp Discovery Series II 1 03-11-2007 08:18 AM
Where can I get... johnnybob06 Discovery Series II 7 02-21-2007 01:44 PM
What should I have done during maintenance? appstatedisco Discovery Series I 2 09-12-2005 07:57 PM
